11 Pages V « < 2 3 4 5 6 > »
> Disco Bay, CA transmission rebuild clinic, June 11-12, taking registration!
jeeperjohn56
post Feb 3 2011, 06:22 AM
Post #61
Mike, That sounds great, Do I have to source out a H or HB gear set? John
Dr Evil
post Feb 3 2011, 10:15 AM
Post #62
Send me your transmission!
Yes. I do not have any.
RJMII
post Feb 4 2011, 09:01 PM
Post #63
Jim McIntosh
I have done several of these and have nothing but accolades from attendees.
accolades and friends that bump threads for a worthwhile weekend trip.
jeeperjohn56
post Feb 6 2011, 05:26 PM
Post #64
Hey Mike, What other gear set would be close to a "H" or "HB" would a "ZD" work? just going by what someone suggested. I have no clue about any of the gearing or cost so all help is appreciated. John
arkitect
post Feb 7 2011, 01:09 PM
Post #65
Mike,
Have not been on the world in awhile, glad to see this is happening in Discovery Bay, just west of Stockton. (IMG:style_emoticons/default/piratenanner.gif)
I'm in, will pm you for where to send the money.
Dave
underthetire
post Feb 7 2011, 01:27 PM
Post #66
Im probably not in. Finances and a blown up engine... I can help others. Was thinking about doing a smoked pulled pork sandwiches for the event...
Dr Evil
post Feb 7 2011, 07:39 PM
Post #67
QUOTE(jeeperjohn56 @ Feb 6 2011, 06:26 PM) *
ZD is the gear already in the box. There is no close to H or HB.
Gudhjem
post Feb 7 2011, 07:45 PM
Post #68
I'm in. Probably only for Saturday though, so will get done as much as I can then.
Mike Bellis
post Feb 7 2011, 08:16 PM
Post #69
Resident Electrician
Well Dr. Evil, I'm looking forward to you telling me what 5th gear I have. My box was rebuilt by a former owner and a taller 5th was installed. I have a little whine in 5th, maybe a flipped H? Sometimes it is a little stif going into 2nd but no grinding. If I shift to 1st, then into 2nd, super smooth.
Dr Evil
post Feb 7 2011, 08:38 PM
Post #70
QUOTE(Gudhjem @ Feb 7 2011, 08:45 PM) *
Not a problem. I have many people do two rebuilds in a weekend so one is totally doable in a day.
Dr Evil
post Feb 7 2011, 08:41 PM
Post #71
QUOTE(kg6dxn @ Feb 7 2011, 09:16 PM) *
Probably a bad bearing. A flipped H doesnt generally howl.
jeeperjohn56
post Feb 8 2011, 06:07 AM
Post #72
Hey Mike, Are you going to get rid of your "H" gear in your box? If so I would be interested in it. John
Mike Bellis
post Feb 8 2011, 10:50 AM
Post #73
QUOTE(jeeperjohn56 @ Feb 8 2011, 04:07 AM) *
I was not planning a full rebuild on mine. It was done recently. I am planning to swap my nose cone for my spare. However, I will not need the taller 5th with my new engine. I am open to negotiations...
Dr Evil
post Feb 8 2011, 03:54 PM
Post #74
Registrations fees arriving now! I will list which ones arrive in the first post and if they reserved parts. (IMG:style_emoticons/default/smile.gif)
Gudhjem
post Feb 13 2011, 09:29 PM
Post #75
Okay Doc, I pulled my gear stack this today and took some pics. Hard to believe you can tell what I might need from these photos. Maybe I need to dismantle a bit more for you to see it?
Attached ImageAttached ImageAttached Image[attachmentid=249
128]Attached ImageAttached Image
Gudhjem
post Feb 13 2011, 09:30 PM
Post #76
A few more:
Dr Evil
post Feb 13 2011, 10:11 PM
Post #77
From those pics alone I see that you need:
1st teeth
2nd teeth
3rd band
2nd band
Take off 1st gear slider and photo the teeth and band. It is only one 13mm bolt.
Dr Evil
post Feb 13 2011, 10:13 PM
Post #78
This is your fist gear slider. The big money part. Remove it and let us see what is under it.
Gudhjem
post Feb 13 2011, 10:43 PM
Post #79
This one?
I think I know the answer (IMG:style_emoticons/default/sad.gif)
Dr Evil
post Feb 14 2011, 07:29 AM
Post #80
Your transmission lived a good life. Your 1st slider is actually reusable (IMG:style_emoticons/default/smilie_pokal.gif)
Your 1st band is in good shape as well, which leads me to believe that someone was in there at one point in the last 10 years. Your 1st teeth still look shot. This is not the normal wear pattern. It usually goes: band-->teeth--> slider. This also just so happens to be the cost curve as well with the cheapest part wearing first.
- Lo-Fi Version Time is now: 2nd December 2025 - 12:34 AM
