| Dr Evil |
Feb 14 2011, 07:31 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Pics of the teeth on second gear slider would be helpful.
| Gudhjem |
Feb 14 2011, 11:04 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 29-March 07 From: Castro Valley, CA Member No.: 7,629 Region Association: Northern California |
second gear would be the one in the middle of this pic?:
![]() The shift fork doesn't want to move. It needs to move away from the intermediate plate? Do I need to move 1st or 5th, or...? (IMG:style_emoticons/default/confused24.gif) |
| Dr Evil |
Feb 15 2011, 04:53 PM
It wont shift into 2nd because it is already in 4th. You need to center the rod that actuates 4-5 and then shift into 3rd. (IMG:style_emoticons/default/smile.gif)
Other Disco Bay folks, feel free to pull your stacks and post pics here so that I can diagnose some of what you need. It will help with parts purchases (IMG:style_emoticons/default/smile.gif) |
| Dr Evil |
Feb 15 2011, 05:22 PM
1st post updated to include Gudjem in the list (IMG:style_emoticons/default/smile.gif)
| kconway |
Feb 15 2011, 06:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Mike,
What if you need to change out the intermediate plate. Is that something that can be done in this clinic? Isn't there a lot of fussing with pinon depth or something equally difficult sounding? *why the intermediate plate...person who was last in my box yielded the threads on the I-plate for the plug cover on the detent ball/springs...haven't filled it yet and run it to see if it leaks or not. Kev |
| Dr Evil |
Feb 15 2011, 06:15 PM
Intermediate plate swap is not a problem (IMG:style_emoticons/default/smile.gif)
| Gudhjem |
Feb 16 2011, 12:20 AM
Alright, I think I've got it. How's this?:
| Dr Evil |
Feb 16 2011, 09:12 AM
The dog teeth on 2nd are worn. The band on 2nd is done. The teeth on the 2-3 slider, 2nd gear side are not visualized so I can not make a call on those. If there are pointy like on the 3rd gear side then they are OK, but I would bet not. I would recommend a replace of the aforementioned parts.
| VaccaRabite |
Feb 16 2011, 09:31 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,812 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Hrm....
This would be my birthday weekend. I could fly out and back for ~500, and just hang out and meet some of the left coast crew.... Kinda tempting.... Zach |
| Dr Evil |
Feb 16 2011, 10:14 AM
Oooooo. Hm?
| underthetire |
Feb 16 2011, 12:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I plan on having the boat in the water by then....I know the other Jeffs is in the water now. (IMG:style_emoticons/default/poke.gif)
| Gudhjem |
Feb 16 2011, 11:57 PM
The dog teeth on 2nd are worn. The band on 2nd is done. The teeth on the 2-3 slider, 2nd gear side are not visualized so I can not make a call on those. If there are pointy like on the 3rd gear side then they are OK, but I would bet not. I would recommend a replace of the aforementioned parts. Another try at the 2d gear side of the 2d/3rd slider. Best angle I think is through the hole in the intermediate plate: ![]() ![]() ![]() |
| Dr Evil |
Feb 17 2011, 06:40 AM
Your photography is pretty amazing (IMG:style_emoticons/default/smile.gif)
2-3 slider looks usable. We will swap positions with 4-5 and bee just fine. (IMG:style_emoticons/default/smile.gif) |
| Dr Evil |
Feb 23 2011, 04:47 PM
If any of you want to pull your stacks and take pics of them and post them here, I can save you some heart ache (IMG:style_emoticons/default/smile.gif) |
| Lennies914 |
Feb 23 2011, 08:33 PM
Slacker ![]() ![]() ![]() Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Hey Doc,
Between Jeff, Dave, and myself (who have not registered yet) we have at least four cores (maybe more). Would you like to look at those to see what is usable? |
| Dr Evil |
Feb 23 2011, 08:36 PM
I only need to see the ones you are rebuilding so I can tell you what you need. At that point we can look at the other cores and see if they have parts to satisfy your needs.
The first thing to consider is if the pinion is good. |
| Mike Bellis |
Feb 23 2011, 09:52 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Dr.
I'm only planning to swap my tail piece. One of the mounting ears is cracked. I do have a core tranny. Where can I get the gasket kit? BTW, have you decided when you want to fly? PM me your info when ready. |
| Dr Evil |
Feb 23 2011, 10:04 PM
Will be in touch. For gasket kits, check out GPR (IMG:style_emoticons/default/smile.gif) Tell them I sent you. Or, I can get them for you (about the same price).
| Dr Evil |
Mar 6 2011, 02:46 AM
1st post updated with current paid attendees.
Also, now that I have the ability to burn my own DVDs, I will be including my transmission rebuild course DVD in the tuition for those who dont already have it (IMG:style_emoticons/default/smile.gif) I will bring them with me. |
| Gudhjem |
Mar 9 2011, 06:58 PM
Doc, I'd like to remove the ring and pinion from the case to make cleaning easier. I take it removing, well, re-installing, the R&P is no problem, right? I just pull it out the side and put it back in the same way. Just checking before I screw it up.
Lo-Fi Version | Time is now: 2nd December 2025 - 12:34 AM |
