Electrical question, Ground |
Black22 |
Feb 1 2011, 08:32 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I have a question regarding wiring my oil temp gauge. My combo gauge has three connectors (+, Ground and G). I found the key-switched power and temp sender wire near the shifter. Those wires tested fine and I extended those wires to the gauge cluster. (IMG:style_emoticons/default/smile.gif)
My question is about the ground wire connection. Should I run a separate ground wire to the common ground location near the fuse box or would it be ok to piggyback the ground on the fuel gauge? (IMG:style_emoticons/default/confused24.gif) I know piggybacking it would ground the gauge but would it affect how either of the gauges read? (IMG:style_emoticons/default/confused24.gif) Thanks Mike |
detoxcowboy |
Feb 1 2011, 08:39 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Piggy Back is fine.. No worries.. I do it. Basically whatever is the cleanest wiring that works. If you get piggy back srazy like maybe then it is cleaner to run a ground and touch them all.. It will not affect your gauge as long as the ground is good.. Gauges and gauge lighting takes such little power you can piggy back that too..
Black22 |
Feb 1 2011, 09:33 PM
Piggy Back is fine.. No worries.. I do it. Basically whatever is the cleanest wiring that works. If you get piggy back srazy like maybe then it is cleaner to run a ground and touch them all.. It will not affect your gauge as long as the ground is good.. Gauges and gauge lighting takes such little power you can piggy back that too.. Thanks for the reply Detox...and thanks for your help the other day on the sender issue. I picked up a sender, p/n 323-092D, from North Hollywood Speedometer for 20 bucks. They were 25-35 bucks online and everywhere else. I haven't installed it yet (waiting for next oil change), but I got all the wiring done! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 03:03 AM |
