new helper |
new helper |
oldschool |
Feb 9 2011, 01:34 AM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
Found this old tire chief....just needs a little paint. it work's pretty good. started to wire brush it today ...paint comes next.
jack's are there just to keep it up, I have the hydro.off |
Tom_T |
Feb 9 2011, 03:00 AM
Just make sure the lift pads hit the jacking doughnuts or one of the other jacking points, so you don't damage the floor pans when lifting. (IMG:style_emoticons/default/shades.gif)
Jack points from someone's illustration posted before on here: You may have to rig something up to hit those safe lifting points in red on the diagram (ignore yellow arrows from something else). |
oldschool |
Feb 9 2011, 11:06 AM
Just make sure the lift pads hit the jacking doughnuts or one of the other jacking points, so you don't damage the floor pans when lifting. (IMG:style_emoticons/default/shades.gif) Jack points from someone's illustration posted before on here: You may have to rig something up to hit those safe lifting points in red on the diagram (ignore yellow arrows from something else). Thanks yes the left is set-up for all cars |
Beach914 |
Feb 9 2011, 11:14 AM
Senior Member Group: Members Posts: 966 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
I just picked one up also. 6K # capacity. I've got it at my Son in Laws shop in Gardena...no room for it at the house right now.
oldschool |
Feb 9 2011, 09:47 PM
I just picked one up also. 6K # capacity. I've got it at my Son in Laws shop in Gardena...no room for it at the house right now. Right on man (IMG:style_emoticons/default/aktion035.gif) |
McMark |
Feb 9 2011, 09:53 PM
Just a little clarification. The front donut is not a suitable jacking point. It's WELL inboard of the long and will bend your floor pans upwards. I beat every floor pan back into place with a sledge hammer. Leave those donuts alone!
The back ones are okay. (IMG:style_emoticons/default/thumb3d.gif) |
oldschool |
Feb 9 2011, 10:08 PM
Just a little clarification. The front donut is not a suitable jacking point. It's WELL inboard of the long and will bend your floor pans upwards. I beat every floor pan back into place with a sledge hammer. Leave those donuts alone! The back ones are okay. (IMG:style_emoticons/default/thumb3d.gif) I thought that's the reason for the donuts? (IMG:style_emoticons/default/confused24.gif) |
dlkawashima |
Feb 9 2011, 11:20 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Just a little clarification. The front donut is not a suitable jacking point. It's WELL inboard of the long and will bend your floor pans upwards. I beat every floor pan back into place with a sledge hammer. Leave those donuts alone! The back ones are okay. (IMG:style_emoticons/default/thumb3d.gif) Do you mean the two donuts marked "g" on the illustration are not suitable jack points? |
rick 918-S |
Feb 10 2011, 12:00 AM
Hey nice rack! -Celette Group: Members Posts: 20,464 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Just a little clarification. The front donut is not a suitable jacking point. It's WELL inboard of the long and will bend your floor pans upwards. I beat every floor pan back into place with a sledge hammer. Leave those donuts alone! The back ones are okay. (IMG:style_emoticons/default/thumb3d.gif) I thought that's the reason for the donuts? (IMG:style_emoticons/default/confused24.gif) In the collision shop those are called check sets. These are the first four fixture locations to see if the center box of the chassis is square and parallel (not twisted)Whether you use a Celette or simple centering gauges these are vital to chassis alignment. You check the center chassis first then work your way out front and rear. |
McMark |
Feb 10 2011, 08:46 AM
Just a little clarification. The front donut is not a suitable jacking point. It's WELL inboard of the long and will bend your floor pans upwards. I beat every floor pan back into place with a sledge hammer. Leave those donuts alone! The back ones are okay. (IMG:style_emoticons/default/thumb3d.gif) Do you mean the two donuts marked "g" on the illustration are not suitable jack points? Correct. |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:54 AM |
