Horn Bracket Nuances, Can I still get a '3 layered' horn bracket somewhere? |
nathansnathan |
Feb 9 2011, 12:55 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
My horn brackets are pretty crusty. They are built like... feeler gauges?
Like there is a stamped ring holding 3 separate bracket pieces together, presumably to prevent breakage caused by flexing. It's hard to find a pic of the back of the original horn to show the ring. Here's a link original horn on ebay If you 'enlarge' then click on the pic of the back you see the ring. Hard to tell from any picture, but the bracket is actually 3 separate layers of steel. and the new version, no ring, seems like a single piece bracket (no ring): (IMG:http://www.914world.com/bbs2/uploads_offsite/www.autohausaz.com-11782-1297277716.1.jpg) I'm pretty sure it'll be hard to come up with used brackets in decent shape. I've seen only the entire horn being sold new, but I'd rather use my original 40 year old horns, as they are probably built better. I'm going to have some stuff plated but the pieces don't really come apart, so it seems to be not an option. Should I just bite the bullet and buy new horns? |
Pat Garvey |
Feb 10 2011, 07:09 PM
My horn brackets are pretty crusty. They are built like... feeler gauges? Like there is a stamped ring holding 3 separate bracket pieces together, presumably to prevent breakage caused by flexing. It's hard to find a pic of the back of the original horn to show the ring. Here's a link original horn on ebay If you 'enlarge' then click on the pic of the back you see the ring. Hard to tell from any picture, but the bracket is actually 3 separate layers of steel. and the new version, no ring, seems like a single piece bracket (no ring): (IMG:http://www.914world.com/bbs2/uploads_offsite/www.autohausaz.com-11782-1297277716.1.jpg) I'm pretty sure it'll be hard to come up with used brackets in decent shape. I've seen only the entire horn being sold new, but I'd rather use my original 40 year old horns, as they are probably built better. I'm going to have some stuff plated but the pieces don't really come apart, so it seems to be not an option. Should I just bite the bullet and buy new horns? You can do that. Or, you just watch & wait. Almost everything/anything comes up as available sooner or later. Though I still have not found the perfect early rain tray I did find a perfect 4 cylinder snowplow. Took almost 20 years, so it is just a matter of time & patience. I'll get that rain tray - just keep watching. |
914werke |
Feb 15 2011, 11:03 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ive got them?
Pat Garvey |
Feb 17 2011, 05:31 PM
Lo-Fi Version | Time is now: 17th May 2024 - 11:39 PM |
