restoration |
restoration |
pauldunn |
Feb 9 2011, 10:21 PM
dudeface Group: Members Posts: 41 Joined: 9-February 11 From: Arizona Member No.: 12,687 Region Association: Southwest Region |
I aquired a '72 914 about 2 years ago and finally got it to my garage. it has been sitting for about 10 years and is lined with a layer of dirt. Suprisingly everthing seems to be in tact. Most of the electrical seems to work except the engine wont turn over with the key. any suggestions? i have an idea, just wanna see if im right.
Mike Bellis |
Feb 9 2011, 10:31 PM
Mike Bellis |
Feb 9 2011, 10:32 PM
pauldunn |
Feb 9 2011, 10:46 PM
Thanks for the color schematics. they will help ALOT. I have built a baja'ed out bug a few years ago. i hear the 914 is real similar, if so how similar? Are parts hard to find? Where is a good place to get some? What are some other common problems i should be aware of?
luskesq |
Feb 9 2011, 10:54 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Just keep checking in with this forum and you'll names. A number of the members have their own specialties and then there are places like Pelican and Auto Atlanta who also check in around here.
good luck, it'll be fun (ha!) keith |
Eric_Shea |
Feb 9 2011, 10:59 PM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/welcome.png)
You found the right place. The poeple here will help. |
Mike Bellis |
The Vendor section here is good. Patrick Motorsports in Pheonix/Mesa area builds some bad ass 914's and other Porsche's. Pelican Parts. Auto Atlanta, Automotion all can mail order stuff. Post a wanted add in the classifieds here first. Many of us have multiple parts laying around.
PanelBilly |
Feb 9 2011, 11:12 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Thanks for the color schematics. they will help ALOT. I have built a baja'ed out bug a few years ago. i hear the 914 is real similar, if so how similar? Are parts hard to find? Where is a good place to get some? What are some other common problems i should be aware of? These cars have a bad habit of planting themselves on a set of jackstands in the garage. Do you best to hind the jackstands If you have a set around it's best to give them to a neighbor and instruct them to only let you have them back for a few hours at a time. |
McMark |
Feb 10 2011, 08:53 AM
Have you had your battery tested? Could be failed.
Take the car out of gear and touch a screwdriver to the starter between the battery cable, and the connector with the small yellow wire (pull the wire off first to make things easier). If the starter bumps over then you've got good battery and so the problem is in the wiring/switch. If it doesn't bump then check your battery/starter. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:06 AM |
