Valve clearance, conflicting info, What to set at? |
jeffdon |
Feb 12 2011, 01:57 PM
I have posted this question before, but wanted to float it out there again. I have rebuilt my 2.0 as a 2056, with Webcam 494, with the rest of the valve train stock (well, new webcam mechanical lifters too). The cam card says to set both intake and exhaust at .006. Elsewhere i see .006 for the intake, .008 for the exhaust.
Whats everyone with a similar set up running? |
76-914 |
Feb 12 2011, 02:34 PM
what kind of pushrods do you have? (IMG:style_emoticons/default/confused24.gif)
jeffdon |
Feb 12 2011, 02:36 PM
Like I said, everything other than the cam and lifters is stock, so I am running the alloy. I know, I know, i should have custom cut some steel ones, but here i am. |
76-914 |
Feb 12 2011, 02:47 PM
.006 / .008
EDIT: If I'm wrong then it will make noise but not burn a valve.IIRC The way I understand it is, aluminum and steel expand more and require the .008" setting. |
Cap'n Krusty |
Feb 12 2011, 03:14 PM
The .008" figure is ONLY for engines with sodium filled exhaust valves and stock pushrods. If you have them, use it. If you think you might have them, or you don't know, use it. If you KNOW you don't have them, it's OK to use .006", but you can still use .008" if you'd like.
The Cap'n |
jeffdon |
Feb 12 2011, 03:23 PM
The .008" figure is ONLY for engines with sodium filled exhaust valves and stock pushrods. If you have them, use it. If you think you might have them, or you don't know, use it. If you KNOW you don't have them, it's OK to use .006", but you can still use .008" if you'd like. The Cap'n Thanks for all the input. Time to go spend some time on the garage floor. |
gothspeed |
Feb 12 2011, 04:13 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I am running new SS valves intake and exhaust, lash caps ....... with Aircooled.Net custom length alloy HD push rods. As far as I know .006" for both is what I am goin with until I hear otherwise.
Mark Henry |
Feb 12 2011, 05:22 PM
I am running new SS valves intake and exhaust, lash caps ....... with Aircooled.Net custom length alloy HD push rods. As far as I know .006" for both is what I am goin with until I hear otherwise. Stock run stock (what the cap'n said), Aircooled .net's AL pushrods I'd run stock but I'd email John and confirm that, Cr-Mo pushrods with adjusters can be set at zero lash. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:32 AM |
