I found my Vibration Gremlin, and rung that lil sob's neck |
76-914 |
Feb 12 2011, 08:42 PM
OK. After a year of chasing my friggin tail I found my vibration. Let the Pontiff begin. I was butt dumb when I first put my 914 together. I didn't want to chance buying a set of tires only to find out that they were too large. So I bought the same size as on it 165/80R15. There weren't that many tires available so I ended up w/ a cheap import tire. I went thru 2 balances, 2 alignments, tire trueing, multiple rotations. I could chase it away momentarily but it would always reappear. I even put the wheels/tires from my '73 on it and no difference. (IMG:style_emoticons/default/WTF.gif) I'd examined the ball joints, tie rod ends and a arm bushings previously but WTF. Besides, Dave and Cesar and everyone else was rebuilding his, so why not. As I separated the ball joint I was thinking "Oh shit" I screwed this up for no reason. It looked really good and showed no slop when forced earlier. Wrong. I was surprised to find that's all it was.
One very interesting foot note. When I switched the larger tires from the '73 earlier, I noticed the increased drag from the weight difference. And both cars have identical brand wheels. It makes me wonder if my car wasn't intended to run the smaller tires. They're faster and they stick to the road like a booger on bus seat. Maybe Porsche tried bigger tires and said "Why?" What do I know. It took me a year to figure this one out. |
McMark |
Feb 12 2011, 08:52 PM
I'm a little confused. You separated the ball joint and replaced it?
Glad to hear you got it sorted out though. |
ChrisFoley |
Feb 12 2011, 09:03 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
silver74insocal |
Feb 12 2011, 09:49 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
(IMG:style_emoticons/default/beerchug.gif) sweet so a new ball joint did it then? you did both sides yeah? i see some in my future as well as tie rods but i got awhile. a gnarly oil leak and new tires are next for me....did you get at your bushings?
phatnine11 |
Feb 12 2011, 10:29 PM
Member Group: Members Posts: 286 Joined: 22-March 05 From: Rancho Cucamonga, CA Member No.: 3,798 |
Kent,
Did cut the balljoint retaining nuts or were you able to use the old ones? Cesar |
76-914 |
Feb 13 2011, 09:53 AM
I'm a little confused. You separated the ball joint and replaced it? Yea, from the bottom of the strut w/ a fork tool. Isw that what you meant? Glad to hear you got it sorted out though. ...Let the Pontiff begin... What does the head of the roman catholic church have to do with wheel vibrations on a 914? A play on Pontificate. In that it was a very "long winded" explanation, Chris. Not a slap at anyones belief system. (IMG:style_emoticons/default/beerchug.gif) sweet so a new ball joint did it then? you did both sides yeah? i see some in my future as well as tie rods but i got awhile. a gnarly oil leak and new tires are next for me....did you get at your bushings? Hey Dave, Did you chase down your gremlins? Both sides, yes. I had planned on doing the bushings but when I got to them I found that they were tighter than socks on a rooster so I left them alone. Whats with the oil leak? Kent, Did cut the balljoint retaining nuts or were you able to use the old ones? Cesar I didn't have to cut them. I made a wrench for them but I honestly believe a 14" pipe wrench works better. The trick is to rotate the wrench, applying pressure at seceral points rather than one. Less chance of getting it out of round plus it help in breaking loose rust and corrosion. |
ChrisFoley |
Feb 13 2011, 10:01 AM
...Let the Pontiff begin... What does the head of the roman catholic church have to do with wheel vibrations on a 914? A play on Pontificate. In that it was a very "long winded" explanation, Chris. Not a slap at anyones belief system. If the pope knew how to repair 914s at least he'd be good for something... ... this from a guy who went to catholic high school. IBTL (IMG:style_emoticons/default/biggrin.gif) |
Als914 |
Feb 13 2011, 11:38 AM
Lighting my way Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California |
...Let the Pontiff begin... What does the head of the roman catholic church have to do with wheel vibrations on a 914? A play on Pontificate. In that it was a very "long winded" explanation, Chris. Not a slap at anyones belief system. If the pope knew how to repair 914s at least he'd be good for something... ... this from a guy who went to catholic high school. IBTL (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/av-943.gif) |
Elliot Cannon |
Feb 13 2011, 02:46 PM
So, was it the cheap ass tires or the ball joints. Your post was as confusing as a 747 captain writing in the log book. (IMG:style_emoticons/default/lol-2.gif)
"Stick like a booger on a bus seat". (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
Spoke |
Feb 13 2011, 05:37 PM
Ball joints will do it.
In PA, those are a oft inspected item. State inspection stations will raise both front wheels, grab the tire at 3 and 9 o'clock and shake back and forth to check tie rods; grab at 12 and 6 o'clock and shake to check for ball joints. Any play in the ball joints or tie rods will be evident in these tests. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:25 PM |
