What is this secondary hose off the fuel overflow? |
detoxcowboy |
Feb 12 2011, 09:45 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Kirmizi |
Feb 12 2011, 09:56 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Does it connect to the expansion tank? (IMG:style_emoticons/default/confused24.gif)
Mike |
detoxcowboy |
Feb 12 2011, 09:58 PM
Possibly is what I was think too as the 914/6 years I do not think had all the "regulations" to follow as of those years.. ?? (IMG:style_emoticons/default/confused24.gif)
John |
Feb 12 2011, 10:04 PM
Interesting.
Parts book shows the TEE as part 914.201.163.10 (The English description reads "Connecting Piece, not with tank ventilation (USA)" To me, looking at the parts, this should be from a non USA car, that came from a car with no carbon filter. |
McMark |
Feb 12 2011, 10:07 PM
From the PET...
detoxcowboy |
Feb 12 2011, 10:09 PM
Yep, Thanks Mark, I remeber that pic from the pet.. that is it.. no charcoal recycling fume system..
Cap'n Krusty |
Feb 12 2011, 10:45 PM
The encircled area shows 2 hoses. The large diameter plastic hose goes from the overflow area to the ground via a hole in the bottom of the car beneath the fuel tank. The smaller cloth covered hose goes from the expansion tank to the filler neck area. There is a 3mm tube to which it attaches.
The Cap'n |
jaxdream |
Feb 13 2011, 08:58 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
So basically , the -6's vented to the ground (IMG:style_emoticons/default/blink.gif) ?? Why didn't the -4's ?? USA emissions regs ?? This would be one way to do away with charcoal canister setup .
Jack / Jaxdream |
Cap'n Krusty |
Feb 13 2011, 10:22 AM
My bad. I couldn't see the tee in the picture. I've never seen one of those on a car. As for venting to the ground, all 914s have that hose, just not with the tee. Sixers had an evap can and hoses, just like the /4s. More research is called for.
The Cap'n |
McMark |
Feb 13 2011, 10:44 AM
The real six here at the shop has that tee on it.
sixerdon |
Feb 13 2011, 11:24 AM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
From the PET... This is the correct set up for all non-cali /6's. The other 47 states and RoW did not require a charcoal canister when sold new. I own both types of /6's here, one with a canister (sold in cali) and one without (sold in Mass). Much has been written on whether or not a canister is needed with a carbed car. It is my belief, they are not. My non canister /6 does not give off fumes even while in the garage after a run and it's a fact that most of the /6's built did not come with a canister. Think about 911's of the era. Same thing. Don |
Lo-Fi Version | Time is now: 17th May 2024 - 12:03 AM |
