Correct oil retun pipe/line for a 6 conversion? |
moparrob |
Feb 13 2011, 11:57 AM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
My donor engine for my 6 conversion came from a '79 3.0 liter, and had this return line on it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1297619879.1.jpg) As far as I can tell, this originally came on a 73-74 911, but was on my engine since it had SSI heat exchangers. My question is: can I use this on my 6 conversion with a stock 914-6 oil tank or will I need a different hard line? I'm running Marty's MSDS headers on my engine - no heat exchangers. If I need a different one, which one is the proper line? Any suggestions on where to buy the complete line setup (I have none other than the hard line) including a thermostat? I heard that Mocal makes one with -12 fittings, which is what my oil tank has welded on it. Thanks in advance. Rob |
Lo-Fi Version | Time is now: 17th May 2024 - 01:49 PM |
