My donor engine for my 6 conversion came from a '79 3.0 liter, and had this return line on it.
As far as I can tell, this originally came on a 73-74 911, but was on my engine since it had SSI heat exchangers.
My question is: can I use this on my 6 conversion with a stock 914-6 oil tank or will I need a different hard line? I'm running Marty's MSDS headers on my engine - no heat exchangers.
If I need a different one, which one is the proper line?
Any suggestions on where to buy the complete line setup (I have none other than the hard line) including a thermostat? I heard that Mocal makes one with -12 fittings, which is what my oil tank has welded on it.
Thanks in advance.
Rob
