Oil cooler set up, what to buy? |
ynotdd |
Apr 29 2004, 07:48 AM
Member Group: Members Posts: 156 Joined: 13-January 03 From: plainview, NY Member No.: 140 |
Ok I'm going to do it . I am going to install a front oil cooler in my 73 2.0 4 autocross/DE car it has an HD oil pump. I ran a search and am thinking of going with the mocal sandwich plate with the thermostat in it and a RX 7 cooler with an 10 lines ran down the rocker panel. please your coments and thought on the subject. (IMG:style_emoticons/default/spank.gif)
Rusty |
Apr 29 2004, 10:10 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Sounds like a good plan... jives with with conventional wisdom.
Be sure to take lots of pictures! -Rusty (IMG:style_emoticons/default/smoke.gif) |
TimT |
Apr 29 2004, 11:09 AM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
The only problem with the RX7 oil coolers is that the inlet and outlets are small... also I believe there is a internal thermostat in the cooler as well.
for not to much extra money you could get a mocal cooler with -12 fittings |
cork |
Apr 29 2004, 12:41 PM
ground zero Group: Members Posts: 49 Joined: 11-January 03 From: phoenix,az Member No.: 132 |
I was going with the rx-7 cooler, I have one if you want to by it, I am going with a Fluidyne after talking to Brad, Fluidynes web site will list places all over the US. Here are a few numbers that were give to me DB-30617, 30616,30416. why the change,by the time you set up, clean the rx cooler, the Fluidyne cooler would be a way to go.
TimT |
Apr 29 2004, 02:24 PM
Tony if you decide to go with the fluidyne cooler call dennis @
ovalspeed. His shop is in Massapequa, phone # usually is in the Metro Post |
ynotdd |
Apr 30 2004, 06:41 AM
Tim
Which cooler do you have? were do you have it? I have been to oval speed before when I buy the parts I plan on using him. keep the money local! |
Trekkor |
Apr 30 2004, 03:53 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Would you explain, please, where the oil fittings take off the engine. (IMG:style_emoticons/default/confused24.gif)
What is an expected price range for a cooler set-up? |
Mark Henry |
Apr 30 2004, 05:33 PM
One method is my mount:
http://www.914world.com/bbs2/index.php?act...t=11163&hl=berg There is also the sandwich adaptor that goes between the filter and filter housing. With stainless lines expect $500+ for the whole set-up. |
TimT |
Apr 30 2004, 06:06 PM
Tony, on my 914 I have a mocal cooler in the front trunk, with a hole cut in the front bulkhead for air to come in, and a hole in the floor to exhaust the air..
The fluidyne is on my 911 |
Lo-Fi Version | Time is now: 28th May 2024 - 06:57 AM |
