Things are happenin', for the WCC |
seanery |
Apr 29 2004, 09:34 AM
(IMG:style_emoticons/default/biggrin.gif) All I can say is if you are on the fence, or interested at all that you really need to go. We've had some really nice developments in the last 24 hours. This will be THE914EVENTOFTHEYEAR.
SIGN UP NOW!!!! |
Ferg |
Apr 29 2004, 11:35 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
May is going to be a long month of waiting... I've already started packing, BTW how much fat tire should I bring. (IMG:style_emoticons/default/beerchug.gif) Ferg |
VegasRacer |
Apr 29 2004, 11:48 AM
ELVIRA Group: Benefactors Posts: 8,507 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
QUOTE(seanery @ Apr 29 2004, 07:34 AM) (IMG:style_emoticons/default/biggrin.gif) All I can say is if you are on the fence, or interested at all that you really need to go. We've had some really nice developments in the last 24 hours. This will be THE914EVENTOFTHEYEAR. SIGN UP NOW!!!! As a member of the planning committee I can honestly tell you this is not B.S. or last minute hype. The plans were good before. Now they are even better (and still improving). If you are not excited - you should be. If there is any way that you can manage to go to the WCC - DO IT! You will only be sorry if you don't. |
Korijo |
Apr 29 2004, 12:39 PM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
the wife hasnt officially given the ok, thats why i am fence ridin'...
Jeff, registration is on the way (IMG:style_emoticons/default/ph34r.gif) (IMG:style_emoticons/default/happy11.gif) |
peridotian |
Apr 29 2004, 12:41 PM
Unregistered |
I would sign up if I knew my car was going to be finished. Are you listening B?
Mueller |
Apr 29 2004, 12:57 PM
Patrick,
you have a running car right now !!!! nobody really cares (besides you, LOL) if you have your 2.0 motor in it at the event......remember how well you guys did at the auto-x???? your new motor is not going to make that much of a difference (IMG:style_emoticons/default/smile.gif) |
rick 918-S |
Apr 29 2004, 02:20 PM
Hey nice rack! -Celette Group: Members Posts: 20,457 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
QUOTE(Korijo @ Apr 29 2004, 10:39 AM) the wife hasnt officially given the ok, thats why i am fence ridin'... Jeff, registration is on the way (IMG:style_emoticons/default/ph34r.gif) (IMG:style_emoticons/default/happy11.gif) I can see it now! (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/smilie_rolli_1.gif) (IMG:style_emoticons/default/driving-girl.gif) |
VegasRacer |
Apr 29 2004, 02:34 PM
Hey Dave, After Rich and I trailered our cars a few thousand miles, it's not that much further up to your house. It would be no real trouble for us to stop by and kick your ass and give you a few noogies if you don't show up at the WCC. (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/splat.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/spank.gif)
peridotian |
Apr 29 2004, 03:38 PM
Unregistered |
I just put my WCC check in the mail to Jeff. See you all there!
Brad Roberts |
Apr 29 2004, 03:40 PM
What do we need to do to get it running smooth again ??
I'm betting it has a clogged injector or the points are failing. B |
peridotian |
Apr 29 2004, 03:48 PM
Unregistered |
Brad,
It quit running after the AX at a gas station in Milpitas. I thought it was vapor lock. I pulled fuel hose and had plenty of fuel pressure. I pulled diz cap and no spark across points. 15 minutes later it started right up. We got almost all the way home with little pee driving and he was doggin it big time going into the wrong gear and lugging the motor and then it started coughing and sputtering and barely made it to the driveway where it died and would not start. The next day it fire right up and is running but somewhat rough with some popping. When I'm on it, it runs fine. If I'm just cruising it pops and feels flat. What thinks you maestro? Patrick |
rick 918-S |
Apr 29 2004, 04:06 PM
QUOTE(peridotian @ Apr 29 2004, 01:48 PM) Brad, It quit running after the AX at a gas station in Milpitas. I thought it was vapor lock. I pulled fuel hose and had plenty of fuel pressure. I pulled diz cap and no spark across points. 15 minutes later it started right up. We got almost all the way home with little pee driving and he was doggin it big time going into the wrong gear and lugging the motor and then it started coughing and sputtering and barely made it to the driveway where it died and would not start. The next day it fire right up and is running but somewhat rough with some popping. When I'm on it, it runs fine. If I'm just cruising it pops and feels flat. What thinks you maestro? Patrick Sounds like the coil is dying. Overheating. Also agree with Brad about the points ached or condensor failing. Doesn't sound like a major problem. Send in that registration |
peridotian |
Apr 29 2004, 04:29 PM
Unregistered |
Coil would be cool, even me the undertalented wrench can replace a coil.
seanery |
Apr 29 2004, 04:35 PM
sounds similar to my dirt-in-the-carb problem I had last week. A little tap-tap-tap on my carb and it was fine. Are injectors more/less susceptible (sp?) than carbs?
Lo-Fi Version | Time is now: 15th May 2024 - 10:35 AM |
