QUOTE(peridotian @ Apr 29 2004, 01:48 PM)
Brad,
It quit running after the AX at a gas station in Milpitas. I thought it was vapor lock. I pulled fuel hose and had plenty of fuel pressure. I pulled diz cap and no spark across points. 15 minutes later it started right up. We got almost all the way home with little pee driving and he was doggin it big time going into the wrong gear and lugging the motor and then it started coughing and sputtering and barely made it to the driveway where it died and would not start. The next day it fire right up and is running but somewhat rough with some popping. When I'm on it, it runs fine. If I'm just cruising it pops and feels flat. What thinks you maestro?
Patrick
Sounds like the coil is dying. Overheating. Also agree with Brad about the points ached or condensor failing. Doesn't sound like a major problem. Send in that registration
