WTB: Early 911/914-6 Heater Tube |
proto31 |
Feb 22 2011, 12:04 AM
Member Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None |
I'm adding heat to my 914/6 conversion and need the plastic piece (part #901 106 327) that is held in by the metal bracket that bolts onto the engine shroud on the driver's side (914, or passenger side for 911). I don't have a soft copy of the PET manual so I can't post a pic. I have the metal brackets that hold it in place, just need the plastic tube. Let me know what you've got.
Thanks, Dan |
bdstone914 |
Feb 22 2011, 01:50 AM
Hi Dan,
I think I have one of those. I will be back in town on the the and can check. I know it is a 911 heater part just not sure if it is what you need. Bruce |
proto31 |
Feb 22 2011, 11:11 AM
Hi Dan, I think I have one of those. I will be back in town on the the and can check. I know it is a 911 heater part just not sure if it is what you need. Bruce Thanks Bruce, keep me posted. On early 911s there are two of these, one for each side. On a 914 (backwards configuration) the passenger side piece is all one piece and is metal, on the driver's side it consists of a metal cover, a holding bracket and the actual plastic tube itself. I just need the the tube. Thanks, Dan |
bdstone914 |
Feb 22 2011, 12:20 PM
The part I have is all one metal piece.
Bruce |
proto31 |
Feb 22 2011, 01:17 PM
proto31 |
Feb 22 2011, 11:50 PM
proto31 |
Mar 7 2011, 07:31 PM
Bump... It's still cold outside, heat would be nice...
moparrob |
Mar 7 2011, 11:11 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Dan,
Is this the one you need? (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1299561113.1.jpg) I have an extra one, which you can have. After all, all I did 'borrow' your front spare mounting idea. (IMG:style_emoticons/default/happy11.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1299561114.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1299561114.3.jpg) PM me to make arrangements for where you want it sent to. Rob |
proto31 |
Mar 7 2011, 11:59 PM
Dan, Is this the one you need? (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1299561113.1.jpg) I have an extra one, which you can have. After all, all I did 'borrow' your front spare mounting idea. (IMG:style_emoticons/default/happy11.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1299561114.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1299561114.3.jpg) PM me to make arrangements for where you want it sent to. Rob That's exactly the one that I need, you're awesome! Wow, nice job on the tire mount, did you actually copy mine (looks almost identical) or did you come up with it on your own? Great job, it looks really clean! I'll send a PM. Dan |
moparrob |
Mar 8 2011, 12:56 AM
Dan, Is this the one you need? (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1299561113.1.jpg) I have an extra one, which you can have. After all, all I did 'borrow' your front spare mounting idea. (IMG:style_emoticons/default/happy11.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1299561114.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1299561114.3.jpg) PM me to make arrangements for where you want it sent to. Rob That's exactly the one that I need, you're awesome! Wow, nice job on the tire mount, did you actually copy mine (looks almost identical) or did you come up with it on your own? Great job, it looks really clean! I'll send a PM. Dan I met you last fall at the 914 swap in Riverside. I was pretty impressed with your setup, so I took some pics and engineered it when I got home. |
sixnotfour |
Mar 8 2011, 03:01 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
FYI the early ones are all steel -68 approx.
proto31 |
Mar 9 2011, 05:02 PM
Rob, got the heater tube today, thanks for getting it out so quick! I owe you one.
Dan |
Lo-Fi Version | Time is now: 18th May 2024 - 01:45 AM |
