Help can't get my doors opened with key |
weird_looking_cactus |
Apr 29 2004, 07:33 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
I just got new outside door handles cause my old ones both broke. I have them on and when I lock the door from the inside it will make it so you can't open it from the outside when using the key. The key works fine it goes in and lets me turn it but it won't unluck it. It the same way on both doors.
URY914 |
Apr 29 2004, 07:51 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,573 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Did you put the little piece on the handle that is held in place by a screw. It is a small metal piece that has an off set pin on it that moves the latch when the key is turned.
See it here at the top of the picture... Paul Attached image(s) |
Apr 29 2004, 08:04 PM
Yep that peace is on the handle when I stuck them on. The door opens just fine and locks just fine its just it won't unlock. Is there anything else it could be. Cause with my old locks before the handles broke they locked and unlock just fine.
URY914 |
Apr 29 2004, 08:07 PM
Did the new handles come with new lock cylinders and keys?
Or did you install the existing ones? Paul |
TheCabinetmaker |
Apr 29 2004, 08:09 PM
Did you unscrew that peice and change the lock inside with the old ones?
URY914 |
Apr 29 2004, 08:13 PM
That's right. If you take the screw out and pull off that piece with the pin on it, the lock cylinder can be pulled out with the key.
Paul |
Apr 29 2004, 08:14 PM
Here is what I bought and just took the old one out and stuck the new ones in.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=34204 |
URY914 |
Apr 29 2004, 08:19 PM
You got a SWEET!! deal.
You may have them on the wrong doors. They would be upside down if they are switched and I don't think they will work. That pin has to rotate in the right direct to unlock the door. You may have to pull one to see. Paul |
VegasRacer |
Apr 29 2004, 08:30 PM
ELVIRA Group: Benefactors Posts: 8,507 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Can you lock the door from the outside with the key?
(you got those handles for a great price) |
Aaron Cox |
Apr 29 2004, 08:37 PM
door handles do work flipped! i know they do....
im guessing you dont have the right key for them. it is EXTREMELY easy to change out lock cylinders. haynes describes it..."adequately"... *put key in lock cyl, unscrew the back of the cylinder...etc. very easy. |
Apr 29 2004, 08:40 PM
When the key in the lock it turns the whole thing cause before I put them in the car I test it. But I will take them out and switch them around that is probley my problem.
URY914 |
Apr 29 2004, 08:44 PM
Why did you relace them, were they broken?
Don't throw the broken ones away. I'll take them off your hands. Paul |
Aaron Cox |
when installing door handles, the "tab" on the backside of the lock has to be engaged in the door locking mechanism.....,
look at the pic in the beginnig of the thread, its the "tab" on the back of the lock hope im making sense (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 07:00 PM |
