Semi-OT: New tow vehicle, Nothing too extravagant, but I'm excited... |
campbellcj |
Feb 25 2011, 12:16 AM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I've been borrowing my wife's daily-driver SUV for years, whenever I needed to tow to the track or haul parts, etc. That got to be a pain for both of us, plus there was just recently an..."incident"...with my Audi one weekend when we'd swapped cars.
Right after that, I noticed a recently retired guy in my neighborhood had a 2001 F150 Supercrew 4x4 5.4L with Lariat trim, shell, bed liner, tow package, original owner, dealer-serviced, and priced below blue book. It seemed ideal for my current needs and is cheap and "used" enough that I won't have to worry about thrashing it. I currently have a steel 16' open trailer but it should have no problem towing a modest enclosed trailer if I ever go that route. |
DanT |
Feb 25 2011, 12:21 AM
Chris, that truck would be able to pull at least a 20' enclosed trailer with no problems.
If you finally go that route just make sure it has brakes on both axles and that you use a good weight distribution hitch. what axle ratios does it have? something like 3:53s? |
Randal |
Feb 25 2011, 06:42 PM
I've been borrowing my wife's daily-driver SUV for years, whenever I needed to tow to the track or haul parts, etc. That got to be a pain for both of us, plus there was just recently an..."incident"...with my Audi one weekend when we'd swapped cars. Right after that, I noticed a recently retired guy in my neighborhood had a 2001 F150 Supercrew 4x4 5.4L with Lariat trim, shell, bed liner, tow package, original owner, dealer-serviced, and priced below blue book. It seemed ideal for my current needs and is cheap and "used" enough that I won't have to worry about thrashing it. I currently have a steel 16' open trailer but it should have no problem towing a modest enclosed trailer if I ever go that route. That truck looks great and you'll appreciate that camper when you go to the track. Like real security for stuff that could walk away! Sure looks clean in the picture. |
brant |
Feb 25 2011, 06:49 PM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Nice!
messix |
Feb 25 2011, 08:50 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
awesome! (IMG:style_emoticons/default/aktion035.gif)
campbellcj |
Feb 26 2011, 01:06 AM
I don't know which final ratio it's got - I think there were 3 options offered - but I'll find that out.
I had an un-fun time retrieving my trailer and loading-up tonight in the rain and dark. Went out to the trailer storage place to discover that I had to flip the ball to lower it vs. how it was set up for the Land Cruiser...oops! And the ball that came with this truck was too small. So I drove back home, flipped it, then carried-on as usual. Except for the rain part. |
campbellcj |
Mar 6 2011, 10:09 PM
FWIW I found out via the door sticker that my F150 has the H9 axle which is the 3.55 limited-slip. Probably not a very common option (along with the 4WD) in this neck of the woods, but the PO bought it in Ohio and moved out here right afterwards.
DanT |
Mar 6 2011, 10:16 PM
fairly common axle ratio Chris...the limited slip is always a good option. (IMG:style_emoticons/default/biggrin.gif)
the real towing monster would be a 3:73 or 4:10s but for what you are going to be doing with it, the 3:55s will be fine...gives you a bit better mileage if you aren't pulling a real heavy load. my Burb had 4:10s and could pull a heavy trailer just about anywhere... I pulled near 8,000#s many times over 10 years. RV, enclosed racecar trailer, open racecar trailer, etc.... your truck looks to be pretty well equipped....does it have a trailer brake controller? on my camping weekends, this is our rig Chevy Duramax and Allison 6 speed trans... 365HP and 660LBFt of torque...@1600 RPMs (IMG:style_emoticons/default/smile.gif) Attached image(s) |
campbellcj |
Mar 6 2011, 10:32 PM
Geez, now that's a torque monster!
Mine doesn't have a brake controller, but I have a new one sitting here. Originally I was planning to install it in the Land Cruiser but never needed it. I'll probably put it in the truck once I figure-out how to do that - not sure where it falls between plug n' play vs. EE degree complexity. Wiring doesn't scare me, as long as I can ascertain what goes where, which is always the tricky part. |
DanT |
Mar 6 2011, 11:10 PM
Chris, check your owner's manual. It may be a plug and play with the proper harness. I know the GMs of that era had that, so I would think the Ford would as well.
What controller do you have? Prodigy is a very nice proportioned controller that does not work with a pendulum...with those units you have to install it in a particular orientation and then calibrate. Check on the controller manufacturers website, they should have plug and play harnesses. |
Brett W |
Mar 14 2011, 03:04 PM
I don't know how big your trailer is, but you probably will want to upgrade the shocks and brake pads, ASAP. Get the Hawk Light Truck Pads and at least Bilstein shocks. Might also look at some stiffer rear springs, swap the tires on it for a full blown E load rating tire. Get rid of the crappy passenger rated tires that are on it now. Definitely get that brake controller hooked up.
You may find that the truck can get many a heavy load moving, but its the stopping part that will leave you worried. I don't think people should be towing a real load with anything smaller than a 3/4 truck, because the half ton trucks just don't have the chassis or brakes to truly control a heavy load. Half ton trucks are cars with a bed. You will probably find the 5.4 marginal at best, fuel mileage will not be so great when towing, the tranny will be constantly confused when you are towing, its best to lock out of overdrive. Also look at the biggest tranny cooler option you can find. It will keep the tranny alive, awhile. You can tow with this thing but there are better options for probably about the same money. |
DanT |
Mar 14 2011, 04:32 PM
I don't know how big your trailer is, but you probably will want to upgrade the shocks and brake pads, ASAP. Get the Hawk Light Truck Pads and at least Bilstein shocks. Might also look at some stiffer rear springs, swap the tires on it for a full blown E load rating tire. Get rid of the crappy passenger rated tires that are on it now. Definitely get that brake controller hooked up. You may find that the truck can get many a heavy load moving, but its the stopping part that will leave you worried. I don't think people should be towing a real load with anything smaller than a 3/4 truck, because the half ton trucks just don't have the chassis or brakes to truly control a heavy load. Half ton trucks are cars with a bed. You will probably find the 5.4 marginal at best, fuel mileage will not be so great when towing, the tranny will be constantly confused when you are towing, its best to lock out of overdrive. Also look at the biggest tranny cooler option you can find. It will keep the tranny alive, awhile. You can tow with this thing but there are better options for probably about the same money. Gee, that was a ringing endorsement..... (IMG:style_emoticons/default/confused24.gif) He is currently towing a 914 on an open trailer....you could tow that with a Toyota Tacoma or a Ford Ranger.... |
campbellcj |
Mar 14 2011, 04:41 PM
Yup. Honestly I can barely feel my trailer+914 with this thing or the Land Cruiser I was pulling it with previously. The total rig is barely 4000 lbs if even that. Going or stopping has never been a problem. Gas mileage while towing is ~12-13 with either vehicle.
That said I am going to check/replace/upgrade the shocks, tires and brakes soon. I just did the trailer tires recently so they're good for some time. The brake controller I have is a Prodigy and it does look very simple to wire-up so that's also on my list to deal with some coming weekend. |
Brett W |
Mar 15 2011, 07:17 AM
I had a thought last night, if you go with a heavier trailer or car, pick up the sway control and the load equalizing hitch. It will do a better job of loading the front tires.
john rogers |
Mar 15 2011, 11:50 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Chris, one of the nice things with a brake controller is the "panic button" that will lock the trailer brakes in an emergency and if the tow vehicle is skidding that will yank it straight in a nanosecond! A bit hard on the trailer tires but can be helpful. Also make sure the trailer has a breakaway switch just in case things come apart. Great looking truck!
campbellcj |
Mar 30 2011, 10:23 PM
Just an update - I got the brake controller installed using the plug n' play harness (thanks for the heads-up on that Dan) and it works great. Also changed the front rotors and all 4 shocks. A few little things too like gas struts on the tail hatch and weathertech floor mats. It's working out great so far.
I'm gonna deal with the tires before the longer tows and road trips coming in the summer. Anybody have recommendations for a good all-weather LT tire? |
DanT |
Apr 8 2011, 09:59 PM
Chris I had these on my Burb for many years and about 45k miles with lots of tread left when I sold a couple years back.
I would go for load range D for towing duty, especially for when you step up to an enclosed trailer in the future. http://www.tirerack.com/tires/tires.jsp?ti...Model=LTX+M%2FS |
campbellcj |
Apr 8 2011, 10:24 PM
Chris I had these on my Burb for many years and about 45k miles with lots of tread left when I sold a couple years back. I would go for load range D for towing duty, especially for when you step up to an enclosed trailer in the future. http://www.tirerack.com/tires/tires.jsp?ti...Model=LTX+M%2FS Thanks again Dan - those may be what my local tire guy has on his personal F250 tow rig. I was eyeballing it in the parking lot while getting my Hoosiers mounted but I didn't get a chance to talk truck tires with him that day. |
messix |
Apr 9 2011, 01:01 AM
Chris I had these on my Burb for many years and about 45k miles with lots of tread left when I sold a couple years back. I would go for load range D for towing duty, especially for when you step up to an enclosed trailer in the future. http://www.tirerack.com/tires/tires.jsp?ti...Model=LTX+M%2FS i second those tires, i have them on my truck and they are very quiet smooth and last a long time. i'm running 285 75 16 on a one ton crewcab towing upto 10,000 lbs of toy hauler and gear on a single axle rear end. very stable and handles the load great. |
campbellcj |
Apr 10 2011, 08:38 PM
Funny coincidence...I just noticed the LTX M/S2 (newer version) is what is on my wife's Land Cruiser. They worked great in our last road trip to Mammoth, including some pretty terrible conditions. Seems like a no-brainer choice.
There is also an LTX A/S tire that seems similar but probably also an older design. Also I finished repainting my trailer today. I got 90% of it done last weekend but the store ran out of paint and I ran out of energy. This is a quick n' dirty rattle can job but it looks vastly improved - tons of surface rust and grunge before. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1302490306.1.jpg) Repainted trailer by cjcam, on Flickr |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:08 PM |
