questions |
questions |
Feb 28 2011, 09:38 PM
The heater blower fan is from a 70-72 car. Chances are pretty good that it's a 1.7 engine. The engine number likely begins with "EA" or "W", and is on the rib below that green return spring on the carb. It could also be further over to the right, where the crankcase turns down and is vertical.
There's also a chance (it wouldn't be the original engine if this is true) that it could be just in front of the oil filler, between it and the fan shroud. --DD |
silver74insocal |
Feb 28 2011, 09:45 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
any chance thats an L97H gold metallic peeking through there?
silver74insocal |
Feb 28 2011, 10:23 PM
pauldunn |
Feb 28 2011, 10:41 PM
dudeface Group: Members Posts: 41 Joined: 9-February 11 From: Arizona Member No.: 12,687 Region Association: Southwest Region |
silver74insocal |
Feb 28 2011, 10:53 PM
maybe its not there i will post a pic of the spot. in the mean time...there should be another tag in the FRONT of the drivers door jam. can you post a pic of that area please? (IMG:style_emoticons/default/popcorn[1].gif)
pauldunn |
Feb 28 2011, 11:06 PM
cant take a good enough picture to read what it says, its too dark in the garage, but this is what it says
Made in western germany Karmann Karosserie NR. 0419560 KUNSTHARZLACK L 97 G What does that mean? |
silver74insocal |
Feb 28 2011, 11:13 PM
from your pics it looks like the engine code is missing from its usual spot. it should be right under the carb return spring you posted. heres the pics of my 2 engines..ones in the car and one on the stand:
you can just make out the first 2 letters the karmann sticker tells you the original paint code of the car the black sticker tells you the man. date and MY im sure more will chime in with better info. i wonder what L97 G paint code is? |
pauldunn |
Mar 1 2011, 08:05 AM
Silver74, your good. Paint code L 97 G is a Gold Metallic. Guess someone didnt like the gold so they painted it red. I wonder what color im gonna paint it.
flipb |
Mar 1 2011, 08:08 AM
Senior Member Group: Members Posts: 1,719 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
i wonder what L97 G paint code is? L97G was Gold Metallic in '71 and '72. http://www.914world.com/bbs2/index.php?act=colors Paul, your car was originally this color. My '74 2.0 came with the Weber Progressive carb like you have there. It's fine for getting it running, although you'll get a lot of hesitation and stumbling in cold weather. Eventually you will probably want to convert to dual carbs or take it back to the original stock FI, if you can find all the parts. |
pauldunn |
Mar 1 2011, 08:38 AM
What parts would i be lookin for? where can i find a list of all the parts associated with fuel injection? on my wiring schematic? im from phoenix, it dont get too cold here. how much would it cost to get it back to original FI?
majkos |
Mar 1 2011, 09:10 AM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
anybody in az. can help this guy?
best bet is to have a local 914'neer to help out. there's alot to having the FI system complete properly. good news, plenty of 1.7 stuff out there. tricky part, do they work, after all this is 40 year old stuff If you're going used. new? ya got money? First thing first take a BIG shop vac and clean her up! Second get a Hayne manual It can help 98% of the time. Oh yeah (IMG:style_emoticons/default/welcome.png) |
silver74insocal |
Mar 1 2011, 09:09 PM
My '74 2.0 came with the Weber Progressive carb like you have there. It's fine for getting it running, although you'll get a lot of hesitation and stumbling in cold weather. Eventually you will probably want to convert to dual carbs or take it back to the original stock FI, if you can find all the parts. (IMG:style_emoticons/default/agree.gif) get it running and enjoy it while you learn about all thats needed for FI. but its your call...seems like you got a lil bit of work ahead of you before you have to worry about (IMG:style_emoticons/default/smile.gif) good luck |
pauldunn |
Mar 1 2011, 09:45 PM
Aint that the truth!!!!! but im up for the task. in the first picture i posted of the front end you can see part of my other project. an old baja bug. it started out pretty much the same way, tore up and not running.
silver74insocal |
Mar 1 2011, 10:09 PM
Aint that the truth!!!!! but im up for the task. in the first picture i posted of the front end you can see part of my other project. an old baja bug. it started out pretty much the same way, tore up and not running. "we can rebuild it...we have the technology.." (IMG:style_emoticons/default/smile.gif) all that wiring under the dash is gonna suck. take the seats out and puts some blankets down say you can lay in there for awhile. i REALLY like the gold cars i would be stoked (IMG:style_emoticons/default/beer.gif) DAve |
tomh |
Mar 1 2011, 11:36 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
gold car?like this
silver74insocal |
Mar 2 2011, 01:33 AM
gold car?like this (IMG:style_emoticons/default/drooley.gif) sher is purty (IMG:style_emoticons/default/drooley.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:15 AM |
