pauldunn
Feb 27 2011, 11:21 PM
As you can tell by my title "newbie", i and new to the world of 914s. I know this model was made from 70-76, and there are a few differant sized engine that were used. my car that i just aquired looks like it has been sitting for quite a while, and all the labels and stickers are long gone. There are quite a few problems to be worked out. Question 1, How do i know what size engine is in my car, assuming it is still stock which i think it is. Question 2 - with battery cables hooked to battery, the 2 red arched light in the fuel level guage blink just like the blinker would weather key is in on position or not. Brake reservoir is bone dry. would that cause the blinking? Ive read on here that there is a "reset" button on the master cylinder? is it an obvious button or will i have to look for it? THanks for the help.
Are these cars carburated or fuel injected? mine looks like it is carburated, but some listings i just found make me worried. If i read my schematic right the computer for the fuel injection plugs into the relay block in the engine compartment, am i correct? If they are fuel injected, and that is where the computer plugs into, i am screwed cause i cant find the computer and that plug is empty. where would the computer be?
- Paul
VaccaRabite
Feb 28 2011, 10:12 AM
The blinking red light is the brake failure warning light. Yes, its due to the res being dry. Fill it with Dot3 and start bleeding the brakes using either a pressure bleeder or the "long tubes" method. LOTS of threads about both here on the site. The reset button will only work once the brakes are full of fluid and the air is bled out.
Engine can be determined a few different ways. What year is your car? it should still have vin tags. Please consider entering your VIN info here:
http://www.914world.com/specs/chasnrs.phpDoes the engine have carbs, or the fuel injection still on it? Posting a pic of the engine would lead many here to be able to tell what the engine is.
Zach
luskesq
Feb 28 2011, 02:09 PM
QUOTE(pauldunn @ Feb 27 2011, 09:21 PM)
- Paul
Assuming you have a four cylinder it came stock fuel injected. The computer would be mounted on the firewall in front of the battery. ECU's are available from a number of sources. If you don't know the year of your car it should be on the tag found on rear of driver's door opening.
livinglobotomy
Feb 28 2011, 02:29 PM
before you do anything.... take the parking brake off. your flashing will disappear as this is the parking brake warning signal and is working as designed.
McMark
Feb 28 2011, 02:35 PM
Or, the parking brake warning light. It's both.
For the best information for you and fun for us, post some pictures of the car, trunks, interior, engine bay and we can tell you all sorts of things that we see.
Dave_Darling
Feb 28 2011, 05:46 PM
Some info on different bits about the 914. Both are a bit outdated now, but much of the info is still quite solid.
FAQ:
http://www.pelicanparts.com/techarticles/9...Darling_FAQ.htmBuyer's Guide:
http://www.pelicanparts.com/914/How_to_buy_a_914.htmNo US-bound four-cylinder 914 ran carbs originally. Only the Sixes and the European-spec 1.8s did.
The blinking lights may be due to the brake warning system (either a loss of pressure or the handbrake being up will trigger it), but both should only come on when the key is on. You may have an ignition switch problem, or something shorting an "always hot" wire to a "switched power" wire.
--DD
bandjoey
Feb 28 2011, 06:10 PM
Post your location. I'll be there's someone close by that can help. Also, when you get more info on the motor - year - etc. post that for additional help.
Simple cars to work on. Best education is to start back about 20 pages and read all of the tech posts here and use the search button.
euro911
Feb 28 2011, 06:27 PM
Since the car has been sitting for some time, check the braking system thouroughly before driving it. The master cylinder and/or calipers and/or any of the hoses could be leaking (hence the empty reservoir).
The PO may have removed the ECU (computer), which you won't need when runing with carbs.
Pix of everything would help to identify what you have for a drive train.
pauldunn
Feb 28 2011, 08:13 PM
i have taken pictures of the car. let me know what else you wanna see.
silver74insocal
Feb 28 2011, 08:17 PM
engine bay please
and
welcome to the madness
pauldunn
Feb 28 2011, 08:22 PM
pauldunn
Feb 28 2011, 08:23 PM
pauldunn
Feb 28 2011, 08:24 PM
pauldunn
Feb 28 2011, 08:25 PM
pauldunn
Feb 28 2011, 08:26 PM
silver74insocal
Feb 28 2011, 08:29 PM
yep somebody put a carb on there for you so dont worry about the ecu. on your last picture showing the green carb return spring, just underneath where it is attached in the back you should see your engine code# stamped on the engine case. if you post the first 2 letters of the # we can tell you what engine you have, or record it and find it in the links previously provided
Lennies914
Feb 28 2011, 08:35 PM
I'm sure more will chime in but, it's a carburated 1.7 or 1.8. I see an a/c compressor also.
pauldunn
Feb 28 2011, 08:42 PM
yes that it is. doubt it has any refridgerant in it though. cant get the engine running enough to tell. and as far as the engine code, where is it? i looked all over that engine bay and cant find anything. will it say in the vin?
majkos
Feb 28 2011, 08:49 PM
if the bumpers are original
the motor a 1.7 with AC
Good god man I would drop the motor and give a good cleaning first
Get rid of the ac, pretty well assuming the refrig. is gone
You have the"Progressive carb" set-up on once was Fuel Injection
silver74insocal
Feb 28 2011, 09:35 PM
QUOTE(pauldunn @ Feb 28 2011, 06:42 PM)
see my last post.
what is that original color? you can see it in the front trunk pic and in the engine bay pic. it looks yellow...but kinda not
Dave_Darling
Feb 28 2011, 09:38 PM
The heater blower fan is from a 70-72 car. Chances are pretty good that it's a 1.7 engine. The engine number likely begins with "EA" or "W", and is on the rib below that green return spring on the carb. It could also be further over to the right, where the crankcase turns down and is vertical.
There's also a chance (it wouldn't be the original engine if this is true) that it could be just in front of the oil filler, between it and the fan shroud.
--DD
silver74insocal
Feb 28 2011, 09:45 PM
any chance thats an L97H gold metallic peeking through there?
silver74insocal
Feb 28 2011, 10:23 PM
pauldunn
Feb 28 2011, 10:41 PM
i know this makes me sound like an idiot, but i still cant find that engine code. i have been out the for the last 30 mins lookin for it. how many digits is it? can someone take a pic of theirs so i can have a referance? here re 2 other placks i found.
Click to view attachmentClick to view attachment
silver74insocal
Feb 28 2011, 10:53 PM
maybe its not there i will post a pic of the spot. in the mean time...there should be another tag in the FRONT of the drivers door jam. can you post a pic of that area please?
pauldunn
Feb 28 2011, 11:06 PM
cant take a good enough picture to read what it says, its too dark in the garage, but this is what it says
Made in western germany
Karmann
Karosserie
NR. 0419560
KUNSTHARZLACK
L 97 G
What does that mean?
silver74insocal
Feb 28 2011, 11:13 PM
from your pics it looks like the engine code is missing from its usual spot. it should be right under the carb return spring you posted. heres the pics of my 2 engines..ones in the car and one on the stand:
Click to view attachmentClick to view attachmentyou can just make out the first 2 letters
the karmann sticker tells you the original paint code of the car
the black sticker tells you the man. date and MY
im sure more will chime in with better info.
i wonder what L97 G paint code is?
pauldunn
Mar 1 2011, 08:05 AM
Silver74, your good. Paint code L 97 G is a Gold Metallic. Guess someone didnt like the gold so they painted it red. I wonder what color im gonna paint it.
flipb
Mar 1 2011, 08:08 AM
QUOTE(silver74insocal @ Mar 1 2011, 12:13 AM)
L97G was Gold Metallic in '71 and '72.
http://www.914world.com/bbs2/index.php?act=colorsPaul, your car was originally
this color. My '74 2.0 came with the Weber Progressive carb like you have there. It's fine for getting it running, although you'll get a lot of hesitation and stumbling in cold weather. Eventually you will probably want to convert to dual carbs or take it back to the original stock FI, if you can find all the parts.
pauldunn
Mar 1 2011, 08:38 AM
What parts would i be lookin for? where can i find a list of all the parts associated with fuel injection? on my wiring schematic? im from phoenix, it dont get too cold here. how much would it cost to get it back to original FI?
majkos
Mar 1 2011, 09:10 AM
anybody in az. can help this guy?
best bet is to have a local 914'neer to help out.
there's alot to having the FI system complete properly.
good news, plenty of 1.7 stuff out there.
tricky part, do they work, after all this is 40 year old stuff
If you're going used.
new? ya got money?
First thing first take a BIG shop vac and clean her up!
Second get a Hayne manual
It can help 98% of the time.
Oh yeah
silver74insocal
Mar 1 2011, 09:09 PM
QUOTE(flipb @ Mar 1 2011, 06:08 AM)
get it running and enjoy it while you learn about all thats needed for FI.
but its your call...seems like you got a lil bit of work ahead of you before you have to worry about
good luck
pauldunn
Mar 1 2011, 09:45 PM
Aint that the truth!!!!! but im up for the task. in the first picture i posted of the front end you can see part of my other project. an old baja bug. it started out pretty much the same way, tore up and not running.
silver74insocal
Mar 1 2011, 10:09 PM
QUOTE(pauldunn @ Mar 1 2011, 07:45 PM)
"we can rebuild it...we have the technology.."
all that wiring under the dash is gonna suck. take the seats out and puts some blankets down say you can lay in there for awhile.
i REALLY like the gold cars i would be stoked
DAve
tomh
Mar 1 2011, 11:36 PM
silver74insocal
Mar 2 2011, 01:33 AM
QUOTE(tomh @ Mar 1 2011, 09:36 PM)
sher is purty
pauldunn
Mar 3 2011, 11:13 PM
