Advice needed: Steps to get a 74 2.0 engine running again |
PBC914 |
Mar 3 2011, 11:43 AM
Member Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
I bought a early 74 2.0 with original fuel injection (built in 8/73)-the car has been sitting for some time and does not run. As the weather gets warmer here in Minneapolis, in May I plan on working on the engine to get it running to determine what else it needs (new clutch/trans. rebuild) etc.
Here's what I plan to do: -change oil -change transmission fluid -change plugs -new vacuum lines -replace the relay board -check the injectors -replace the fuel lines -replace fuel filter -new battery -2 new ground straps -new air filter -new distributor and cap -new shifter bushings -new fuses What else do I need to do? Replace? Thanks for your time and input! Paul |
VaccaRabite |
Mar 3 2011, 11:55 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Does the engine turn over by hand, or is it seized?
if you turn the key to start it, does anyhting happen? Do you hear the fuel pump, etc? Zach |
PBC914 |
Mar 3 2011, 11:57 AM
Does the engine turn over by hand, or is it seized? if you turn the key to start it, does anyhting happen? Do you hear the fuel pump, etc? Zach Unfortunately I won't know until I pull it from the location it is sitting in May. I will presume right now that it is not seized (it's a cheaper presumption!) |
dr914@autoatlanta.com |
Mar 3 2011, 12:03 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
valve adjust, valve adjust, valve adjust!!!
quote name='PBC914' date='Mar 3 2011, 10:43 AM' post='1439307'] I bought a early 74 2.0 with original fuel injection (built in 8/73)-the car has been sitting for some time and does not run. As the weather gets warmer here in Minneapolis, in May I plan on working on the engine to get it running to determine what else it needs (new clutch/trans. rebuild) etc. Here's what I plan to do: -change oil -change transmission fluid -change plugs -new vacuum lines -replace the relay board -check the injectors -replace the fuel lines -replace fuel filter -new battery -2 new ground straps -new air filter -new distributor and cap -new shifter bushings -new fuses What else do I need to do? Replace? Thanks for your time and input! Paul [/quote] |
VaccaRabite |
Mar 3 2011, 12:20 PM
Does the engine turn over by hand, or is it seized? if you turn the key to start it, does anyhting happen? Do you hear the fuel pump, etc? Zach Unfortunately I won't know until I pull it from the location it is sitting in May. I will presume right now that it is not seized (it's a cheaper presumption!) until you have it in your hands, here are the basics and I would not worry about other stuff until you can tell if the engine even turns. 1) fuel lines and filters - assume they will be old and crumbly and just waiting to catch your car on fire. replace ALL of them. Even plan on replacing the ones that go through the tunnel with stainless steel. Fire sucks. 2) Oil. Brad Penn 20-50 RACING oil (if the oil is not green, it is the wrong BP oil). Buy a case. 3) Air filter element. 4) Plugs and plug wires. This could be a wait and see, but I would just plan on replacing them. ALL the other stuff - even valve adjustments - should go on the "wait and see" list. Adjusting the valves won't cause a siezed engine to turn, unless they are so far out that there is piston to valve contact being made (which would be bad). |
PBC914 |
[quote name='dr914@autoatlanta.com' date='Mar 3 2011, 12:03 PM' post='1439317']
valve adjust, valve adjust, valve adjust!!! quote name='PBC914' date='Mar 3 2011, 10:43 AM' post='1439307'] I bought a early 74 2.0 with original fuel injection (built in 8/73)-the car has been sitting for some time and does not run. As the weather gets warmer here in Minneapolis, in May I plan on working on the engine to get it running to determine what else it needs (new clutch/trans. rebuild) etc. Here's what I plan to do: -change oil -change transmission fluid -change plugs -new vacuum lines -replace the relay board -check the injectors -replace the fuel lines -replace fuel filter -new battery -2 new ground straps -new air filter -new distributor and cap -new shifter bushings -new fuses What else do I need to do? Replace? Thanks for your time and input! Paul [/quote] [/quote] So what I hear you saying is....Thanks George. |
PBC914 |
Mar 3 2011, 12:23 PM
Does the engine turn over by hand, or is it seized? if you turn the key to start it, does anyhting happen? Do you hear the fuel pump, etc? Zach Unfortunately I won't know until I pull it from the location it is sitting in May. I will presume right now that it is not seized (it's a cheaper presumption!) until you have it in your hands, here are the basics and I would not worry about other stuff until you can tell if the engine even turns. 1) fuel lines and filters - assume they will be old and crumbly and just waiting to catch your car on fire. replace ALL of them. Even plan on replacing the ones that go through the tunnel with stainless steel. Fire sucks. 2) Oil. Brad Penn 20-50 RACING oil (if the oil is not green, it is the wrong BP oil). Buy a case. 3) Air filter element. 4) Plugs and plug wires. This could be a wait and see, but I would just plan on replacing them. ALL the other stuff - even valve adjustments - should go on the "wait and see" list. Adjusting the valves won't cause a siezed engine to turn, unless they are so far out that there is piston to valve contact being made (which would be bad). Much appreciated-I'll update my progress in May. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:55 PM |
