I bought a early 74 2.0 with original fuel injection (built in 8/73)-the car has been sitting for some time and does not run. As the weather gets warmer here in Minneapolis, in May I plan on working on the engine to get it running to determine what else it needs (new clutch/trans. rebuild) etc.
Here's what I plan to do:
-change oil
-change transmission fluid
-change plugs
-new vacuum lines
-replace the relay board
-check the injectors
-replace the fuel lines
-replace fuel filter
-new battery
-2 new ground straps
-new air filter
-new distributor and cap
-new shifter bushings
-new fuses
What else do I need to do? Replace?
Thanks for your time and input!
Paul
