What spark plugs do you guy prefer? |
rick 918-S |
Mar 11 2011, 02:07 PM
Hey nice rack! -Celette Group: Members Posts: 20,463 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
What have you found to work well in your 2.0 injected engine?
underthetire |
Mar 11 2011, 02:08 PM
Ngk b6 something or other
rick 918-S |
Mar 11 2011, 02:38 PM
I usually buy Bosch but I haven't had an air cooled engine on the road for several years.
Drums66 |
Mar 11 2011, 02:42 PM
Ngk b6 something or other .......Yeah those & something or other Bosch (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/smoke.gif) |
Cap'n Krusty |
Mar 11 2011, 02:59 PM
NGK B6ES or Bosch W7CC.
The Cap'n |
rick 918-S |
Mar 11 2011, 06:23 PM
Jeffs9146 |
Mar 11 2011, 08:34 PM
I have always gotten the best results with the BP6ES & BP7ES NGK's! If my car is running a bit rich I use the 7's!
Edit: Sorry your right 7's under normal and 6's if running rich! All I know is what has worked on my car! |
Cap'n Krusty |
Mar 11 2011, 08:51 PM
I have always gotten the best results with the BP6ES & BP7ES NGK's! If my car is running a bit rich I use the 7's! The 7 is too cold for your engine, especially if: (A) It's running rich, and (B) You're using oxygenated fuels. And you are. You'd probably be better off running 5s. Besides all that, you're running extended tip plugs, which weren't installed in 911s until sometime around 1980, IIRC. The Cap'n |
underthetire |
Mar 11 2011, 10:22 PM
Where to find non platinum bosch's though?
SLITS |
Mar 11 2011, 10:26 PM
Bosch Copper is my choice for both /4 & /6. NGK is next in line,
hot_shoe914 |
Mar 11 2011, 10:40 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
I have had much better results with the NGKs, Bosch just isn't what it used to be since they changed them.
JFJ914 |
Mar 12 2011, 10:27 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
NGK B6ES or BOSCH W7CC. Collective wisdom ( the Cap't IIRC) sez use the NGK's
CG-914 |
Mar 12 2011, 11:43 AM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
BOSCH
underthetire |
Mar 12 2011, 11:46 AM
My question remains, were to get Bosch non platinums?
sww914 |
Mar 12 2011, 12:06 PM
GPR
underthetire |
Mar 12 2011, 12:51 PM
Gint |
Mar 12 2011, 08:01 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I've been using NGK's for over 25 years. Including all of my 914's, fours and sixes. I've heard more than one person in the last ten years tell me about Bosch plugs they bought that were bad out of the box.
rick 918-S |
Mar 12 2011, 11:00 PM
I've been using NGK's for over 25 years. Including all of my 914's, fours and sixes. I've heard more than one person in the last ten years tell me about Bosch plugs they bought that were bad out of the box. (IMG:style_emoticons/default/idea.gif) |
Cap'n Krusty |
Mar 12 2011, 11:21 PM
FLAPs sell plats because the profit margin is far higher and the co-op advertising is huge. I use NGKs because the heat range is wider.
The Cap'n |
avidfanjpl |
Mar 13 2011, 12:17 AM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
Help me solve something related to my Bosch plugs.
This is a totally stock 73 2.0L Djet. It is running lean. Plugs look cold and light beige. Joe Sharp said I was too lean. How do I pick a better plug or make it run less lean? At first years ago I was blackening the plugs, but then timing and a new harness from from Jeff B seems to make it run lean. is there something else to do besides plugs? I am pretty sure timing is spot on at 27BTDC at 3300 rpm. Checked it 3 times. Thanks! John |
Lo-Fi Version | Time is now: 21st May 2024 - 12:56 AM |
