rick 918-S
Mar 11 2011, 02:07 PM
What have you found to work well in your 2.0 injected engine?
underthetire
Mar 11 2011, 02:08 PM
Ngk b6 something or other
rick 918-S
Mar 11 2011, 02:38 PM
I usually buy Bosch but I haven't had an air cooled engine on the road for several years.
Drums66
Mar 11 2011, 02:42 PM
Cap'n Krusty
Mar 11 2011, 02:59 PM
NGK B6ES or Bosch W7CC.
The Cap'n
rick 918-S
Mar 11 2011, 06:23 PM
QUOTE(Cap'n Krusty @ Mar 11 2011, 02:59 PM)
The Cap'n
Thanks Cap'n If both perform equally I run the Bosch.
Jeffs9146
Mar 11 2011, 08:34 PM
I have always gotten the best results with the BP6ES & BP7ES NGK's! If my car is running a bit rich I use the 7's!
Edit: Sorry your right 7's under normal and 6's if running rich! All I know is what has worked on my car!
Cap'n Krusty
Mar 11 2011, 08:51 PM
QUOTE(Jeffs9146 @ Mar 11 2011, 06:34 PM)
The 7 is too cold for your engine, especially if: (A) It's running rich, and (B) You're using oxygenated fuels. And you are. You'd probably be better off running 5s. Besides all that, you're running extended tip plugs, which weren't installed in 911s until sometime around 1980, IIRC.
The Cap'n
underthetire
Mar 11 2011, 10:22 PM
Where to find non platinum bosch's though?
SLITS
Mar 11 2011, 10:26 PM
Bosch Copper is my choice for both /4 & /6. NGK is next in line,
hot_shoe914
Mar 11 2011, 10:40 PM
I have had much better results with the NGKs, Bosch just isn't what it used to be since they changed them.
JFJ914
Mar 12 2011, 10:27 AM
NGK B6ES or BOSCH W7CC. Collective wisdom ( the Cap't IIRC) sez use the NGK's
CG-914
Mar 12 2011, 11:43 AM
BOSCH
underthetire
Mar 12 2011, 11:46 AM
My question remains, were to get Bosch non platinums?
sww914
Mar 12 2011, 12:06 PM
GPR
underthetire
Mar 12 2011, 12:51 PM
QUOTE(sww914 @ Mar 12 2011, 10:06 AM)
GPR
Thank you. I need to order some gaskets from them. The last set I got from pmb were platinum, had trouble finding the old coppers.
Gint
Mar 12 2011, 08:01 PM
I've been using NGK's for over 25 years. Including all of my 914's, fours and sixes. I've heard more than one person in the last ten years tell me about Bosch plugs they bought that were bad out of the box.
rick 918-S
Mar 12 2011, 11:00 PM
QUOTE(Gint @ Mar 12 2011, 08:01 PM)
Cap'n Krusty
Mar 12 2011, 11:21 PM
FLAPs sell plats because the profit margin is far higher and the co-op advertising is huge. I use NGKs because the heat range is wider.
The Cap'n
avidfanjpl
Mar 13 2011, 12:17 AM
Help me solve something related to my Bosch plugs.
This is a totally stock 73 2.0L Djet.
It is running lean. Plugs look cold and light beige.
Joe Sharp said I was too lean. How do I pick a better plug or make it run less lean?
At first years ago I was blackening the plugs, but then timing and a new harness from from Jeff B seems to make it run lean.
is there something else to do besides plugs?
I am pretty sure timing is spot on at 27BTDC at 3300 rpm. Checked it 3 times.
Thanks!
John
r_towle
Mar 13 2011, 11:12 AM
QUOTE(rick 918-S @ Mar 11 2011, 08:23 PM)
The Cap'n
I suggest you buy two or three sets and have them on hand.
They are getting hard to get at the local store nowadays...just have them sell you a few sets.
I replace them often..
Rich
underthetire
Mar 13 2011, 12:02 PM
QUOTE(avidfanjpl @ Mar 12 2011, 11:17 PM)
Thanks!
John
Plugs ain't gonna help a lean condition. Check your fuel pressure first. You can unplug the air temp sensor on the plenum to richen things up. There are also a bunch of other settings that can affect it.
avidfanjpl
Mar 14 2011, 11:55 PM
Air temp sensor. EASY and Interesting!
Will try it tomorrow and take a drive.
Thanks!
John
Bazza
Aug 9 2011, 12:41 PM
Gang,
I've finally gotten around to new plugs, which hadn't been touched since I bought her a few years ago.
Here's how the old Bosch WR7CC's looked - a little rich I'd say.
Click to view attachmentSo I picked up a new set of NGK BP6ES, which should run a bit hotter and help with that rich condition, I hope.
They had them "in stock" at the FLAPS.
I'll let you know how they work out.
Cheers,
Baz
avidfanjpl
Aug 9 2011, 02:23 PM
Bosch plugs gapped to 027, I believe. They run nice and light beige.
I change them every other oil change.
John
QUOTE(rick 918-S @ Mar 11 2011, 01:07 PM)
Bazza
Aug 9 2011, 02:28 PM
Everything went smooth on the change-out. Plugs were VERY easy to access - unlike the other Porsches!
Car runs GREAT! Not sure if I can tell any seat of the pants difference but down the road when I take them out I guess I'll be able to compare with the old Bosch's.
2.0 power baby!!!
