Strippers?, Whats the best kind? |
pete |
Mar 12 2011, 08:36 PM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
What's the best paint stripper? I've tried POR-Strip. Not impressed. Any special techniques?
messix |
Mar 12 2011, 08:41 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
cheap ones with low self esteem and no morals......
iamchappy |
Mar 12 2011, 08:51 PM
I've had good luck with aircraft stripper. and also ones with low self esteem and were amoral....
pete |
Mar 12 2011, 08:52 PM
messix |
Mar 12 2011, 09:00 PM
give the cheap strippers some sand paper duh! (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/lol-2.gif)
URY914 |
Mar 12 2011, 09:05 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Young and dumb. Working thier way thru law school.
pktzygt |
Mar 12 2011, 09:17 PM
Member Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
give the cheap strippers some sand paper duh! (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/lol-2.gif) Or a soda blaster. There are too many of us dirty-minded guys on this forum. But seriously, I have an eastwoods soda/abrasive blaster. You need to have a decent compressor, but it was cheap and I think cleaning up with a vacuum is much better than whatever you have to use to get the stripper out of your car after the deed is done. I tried to be serious. |
underthetire |
Mar 12 2011, 09:19 PM
Ones with daddy issues are perfect for me. jabsco gold. Need to add some acid to it to really kick it in hi gear. I'd have to ask my dad, since he did the whole thunderbird with the stuff.
Lou W |
Mar 12 2011, 09:23 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Use a brush and apply one direction only.
markb |
Mar 12 2011, 09:27 PM
I've had good luck with aircraft stripper. and also ones with low self esteem and were amoral.... (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/biggrin.gif) |
bandjoey |
Mar 12 2011, 09:28 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Aircraft from Home Depot works great. It also helps to dress in a feather boa while scraping. (IMG:style_emoticons/default/av-943.gif)
iamchappy |
Mar 12 2011, 09:49 PM
And very important, dont forget, wear protection...
IronHillRestorations |
Mar 12 2011, 11:35 PM
I'll 3rd the aircraft stripper, paint it on with one brush stroke and no 2nd brushing, cover with clear plastic while still wet, let sit for an hour or more.
914itis |
Mar 13 2011, 12:04 AM
Use a brush and apply one direction only. (IMG:style_emoticons/default/agree.gif) Use a wire metal brush. i just used it on my rims and worked like magic. |
pete |
Mar 13 2011, 07:32 AM
Aircraft from Home Depot works great. It also helps to dress in a feather boa while scraping. (IMG:style_emoticons/default/av-943.gif) I don't think I've seen Aircraft at HD. I left the POR-Strip on over night and nothing. Looks like just another layer of crap to strip off now. Does anyone know if temperature has anything to do with it? Its only 45 degrees in the garage. |
rick 918-S |
Mar 13 2011, 07:49 AM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Aircraft stripper. If your having trouble Sand with 80 grit first to break the gloss. Working in a tight place like engine bays Wear full eye, face and arm protection. Use in a very well ventelated area. The fumes will over power you. If you can't work outsde or have a fan running blowning fresh air at you wait until you can. Not that I would ever go to a strip joint but if I did I would have a real weakness for the blonde with the brazilian.
wrightee |
Mar 13 2011, 08:19 AM
Member Group: Members Posts: 83 Joined: 18-November 09 From: Montclair, VA Member No.: 11,053 Region Association: MidAtlantic Region |
Advice given to me for both strippers and 914 restoration candidates: "Start with a Good Body!"
McMark |
Mar 13 2011, 12:24 PM
You shouldn't let paint stripper dry. If you left the POR-Strip on overnight, it's dried out and re-adhered. I like Aircraft (as mentioned), but you can't paint it on and walk away. You have to scrape it while it's still wet.
roadster fan |
Mar 13 2011, 12:36 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
cheap ones with low self esteem and no morals...... (IMG:style_emoticons/default/av-943.gif) Troy you need to stay out of the inside of my brain! Jim |
messix |
Mar 13 2011, 12:44 PM
cheap ones with low self esteem and no morals...... (IMG:style_emoticons/default/av-943.gif) Troy you need to stay out of the inside of my brain! Jim now thats disturbing (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 12:19 AM |
