Inner Long Replacement in Hell Hole, Could use some advice on how to weld it to front section |
saigon71 |
Mar 13 2011, 06:14 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I have been following quite a few of the build threads related to this subject, but I am still a little confused about how this replacement panel gets attached at the front. Do you butt weld it with a sleeve? It looks as though it will "wrap" around the section running back from below the door...do you lap weld it and sleeve it? I left the section running back from the door a little long so I can trim it after I figure out how this thing goes together. Hopefully the attached pics help to explain the situation.
Lo-Fi Version | Time is now: 20th May 2024 - 12:18 AM |
