| RustyWa |
Apr 12 2003, 08:36 PM
Working Member ![]() ![]() ![]() Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
I came out of the store this afternoon and noticed that the running lights on the left side of my car were on. Checked the switch and it was off....hmm.
I had the lights on before I ran into the store..so I cycled the switch a few times, but the lights stayed on. The right side of the car did worked normally. Signals on both sides worked fine too. I decided to pull the fuse on that side and drove home. Back in the garage, I put the fuse back in and everything was working again... Is this signs of the switch going bad?? |
| campbellcj |
Apr 12 2003, 08:39 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,706 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
Did ya by any chance have your turn signal on? (IMG:style_emoticons/default/wink.gif)
| MarkV |
Apr 12 2003, 08:44 PM
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Like Chris said, if you activate turn signal w/ key off it will light parking lights on that side. Nifty 70's parking safety lights ?? (IMG:style_emoticons/default/flag.gif)
| Curvie Roadlover |
Two trunks are better than one! ![]() ![]() ![]() ![]() Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
Yup, check the turn signal. I've seen that before with my car. Shut it off with a turn signal on and that side's running lights stay on.
| RustyWa |
Apr 13 2003, 12:08 AM
Chris, at first I thought you were being a smart ass. (IMG:style_emoticons/default/biggrin.gif)
But come to think of it, I did make a left turn into the parking lot and continued turning left until I stopped in the parking spot. I'll take a look at that tomorrow. Thanks!! |
| seanery |
Apr 13 2003, 09:27 AM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I think that was done because some countries in europe used to (still do?) make you put your outside (street side) "parking" light on when the car is parked. I just found out that my 944 turbo does this I knew the old cars: my 35 6 & 914 did it. So, at least in '86 it was still done somewhere.
| campbellcj |
Apr 13 2003, 11:05 AM
Several of the German cars I've owned were wired this way. I'm not sure if it was a requirement in Europe or just an optional "safety feature" of the cars to help them avoid getting hit while parked on the side of the road.
| SirAndy |
Apr 13 2003, 11:58 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(campbellcj @ Apr 13 2003, 09:05 AM) Several of the German cars I've owned were wired this way. I'm not sure if it was a requirement in Europe or just an optional "safety feature" of the cars to help them avoid getting hit while parked on the side of the road. we don't have sidemarkes in germany. we use the blinkers or headlights as "parking-lights". turn off the car and move the blinker either right or left and that side will light up. normally, that would be the headlights. but because they're not visible, the 914 came with the "euro" lenses, which had a white parking light. here in the US you have the side-markers instead ... Andy |
Lo-Fi Version | Time is now: 16th April 2026 - 08:00 AM |
