5-lug Conversion from 72 911T, Questions on Rear Hub Use |
Spoke |
Mar 16 2011, 10:40 AM
I'm picking up this suspension from a 72 911T for my 5-lug conversion.
For the front, I need just the uprights/hubs/rotors/calipers. For the rear, I would like to use at least the hub. I've heard the spline is different than the 914 half shaft. What do I have to do to use the hub? What about the vented rotor? The rear calipers are gone. I can use spacers on my existing 914 calipers. Is it worth it to use vented rotors on the rear. If I decide to stay with solid rotor, do I order 914/6 rotors? Thanks in advance. Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:40 PM |
