1974 914 starting problems, starting issues |
joe15701 |
Mar 18 2011, 02:46 PM
Newbie Group: Members Posts: 21 Joined: 13-March 11 From: Indiana,pa Member No.: 12,821 Region Association: North East States |
joe15701 |
Mar 18 2011, 02:50 PM
You seem to be ignoring the several posts now about the flapper/AFM. im checking into that now, i seen the symptoms im having can be caused by this,, as well.. im looking into how to test it to see if it is working. do you know of a way, to check to see if the flapper is worker or if the unit itself works. I wasn't ignoring im taking this all in, i had received all the other parts. i was waiting on. so was hoping changing all of the other things, I would of stumbled apon the problem. sorry if i seemed as i was, im just learning a little here and there and running out to the car, and trying different things. |
silver74insocal |
Mar 18 2011, 04:34 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
You seem to be ignoring the several posts now about the flapper/AFM. im checking into that now, i seen the symptoms im having can be caused by this,, as well.. im looking into how to test it to see if it is working. do you know of a way, to check to see if the flapper is worker or if the unit itself works. I wasn't ignoring im taking this all in, i had received all the other parts. i was waiting on. so was hoping changing all of the other things, I would of stumbled apon the problem. sorry if i seemed as i was, im just learning a little here and there and running out to the car, and trying different things. see my first post...its the one with the zombie on the left (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Mar 18 2011, 09:16 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Are you getting fuel?
If not, is there a white (may have faded to kinda tan) wire hooked up to the (-) terminal on the coil? The FI needs the signal from the ignition points to know when to inject fuel. No signal, no fuel. BTW, L-jet does not have "trigger points" in the distributor. That is D-jet. --DD |
Jeffs9146 |
Mar 18 2011, 09:44 PM
QUOTE L-jet does not have "trigger points" in the distributor (IMG:style_emoticons/default/blink.gif) guess I missed that class!! So where are the injectors triggered from? |
Black22 |
Mar 19 2011, 12:54 AM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
You seem to be ignoring the several posts now about the flapper/AFM. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 12:25 PM |
