help removing old sail panel/roll bar glue |
silver74insocal |
Mar 16 2011, 06:11 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
i've tried nothing and i'm all out of ideas (IMG:style_emoticons/default/biggrin.gif) jk. goof off and brake cleaner dont even seem to dent it. is there any easy method? or just a healthy dose of elbow grease and a plastic scraper?
any help will get you much appreciation and a (IMG:style_emoticons/default/beer.gif) drank in your honor TIA, Dave |
Cheapsnake |
Mar 16 2011, 07:01 PM
Member Group: Members Posts: 419 Joined: 15-November 07 From: Door County, WI Member No.: 8,341 |
By the time you find a solvent to cut through the adhesive and finally get it scraped off, you might as well get yourself some aircraft stripper and take it down to bare metal. That stuff is nasty and gets worse with age.
Tom |
silver74insocal |
Mar 16 2011, 07:09 PM
By the time you find a solvent to cut through the adhesive and finally get it scraped off, you might as well get yourself some aircraft stripper and take it down to bare metal. That stuff is nasty and gets worse with age. Tom well thats encouraging (IMG:style_emoticons/default/biggrin.gif) thanks |
Eric_Shea |
Mar 16 2011, 09:24 PM
Goof-off worked for me. Maybe try a more agressive solvent on a rag and let it sit on top of the glue.
AZ914 |
Mar 16 2011, 09:27 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
What are you going to do with the sails? Leave them bare or put vinyl back on? If vinyl.. just sand down any high spots and re-apply adhesive for the next vinyl...
rick 918-S |
Mar 16 2011, 09:28 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
3M brand adhesive remover sold in bodyshop supply stores.
silver74insocal |
Mar 16 2011, 10:19 PM
thanks for the responses guys. new vinyl is going on but i would imagine the adhesive would work better if old glue is completely removed. gues i'll head to the body shop supply house tomorrow, thanks guys (IMG:style_emoticons/default/beerchug.gif) Dave
windforfun |
Mar 17 2011, 10:43 AM
Senior Member Group: Members Posts: 1,789 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Have you tried straight acetone?
Mar 17 2011, 11:40 AM
3m adhesive remover, 3m gasket remover, alchohol, acetone, laquer thinner.
Of the last three, one of them will get it. That is the order I would go. Let none of these hit the rest of the paint....cover that area below with plastic. |
Rex-n-effect |
Mar 17 2011, 12:48 PM
Newbie Group: Members Posts: 44 Joined: 4-February 11 From: Missoula, MT Member No.: 12,659 Region Association: None |
3m adhesive remover, (IMG:style_emoticons/default/agree.gif)
JeffBowlsby |
Mar 17 2011, 02:34 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Acetone may remove the paint...
Seems to me its just rubber-based cement, and that plain ole paint thinner will take it off. |
Mar 17 2011, 02:46 PM
Acetone may remove the paint... Seems to me its just rubber-based cement, and that plain ole paint thinner will take it off. On the stock paint on my VW, my BMW, and my 914, acetone did not harm the paint...nor did laquer thinner or alchohol. Have alot of pine trees here and I get sap on them.,....which seems impervious to anything I can buy aside from sandpaper. Rich |
Pat Garvey |
Mar 17 2011, 03:58 PM
Last time I did it (20+ years ago) I thought about acetone, but it's way too volatile and not exactly good for your lungs. Used 3m adhesive remover copiously & let it sit for about 30 minutes. Used a plastic scraper & got most of it. Used my fingers to get the little balls that just moved around. Takes some patience, but it'll come off. Ventilate!
Pat |
Drums66 |
Mar 17 2011, 04:35 PM
...Goo gone(citrus cleaner)get drunk! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/flag.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/yellowsleep[1].gif) |
Mike Bellis |
Mar 17 2011, 04:49 PM
80 grit sanding disc on a 4" angle grinder... That will take it off... and the paint... and your skin... and... and... (IMG:style_emoticons/default/evilgrin.gif)
Socalandy |
Mar 17 2011, 04:57 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
3M remover works great!!
windforfun |
Mar 17 2011, 05:08 PM
Last time I did it (20+ years ago) I thought about acetone, but it's way too volatile and not exactly good for your lungs. Used 3m adhesive remover copiously & let it sit for about 30 minutes. Used a plastic scraper & got most of it. Used my fingers to get the little balls that just moved around. Takes some patience, but it'll come off. Ventilate! Pat Acetone is virtually harmless unless swallowed. However, don't smoke when you use it. (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/smoke.gif) |
Mar 17 2011, 05:10 PM
Last time I did it (20+ years ago) I thought about acetone, but it's way too volatile and not exactly good for your lungs. Used 3m adhesive remover copiously & let it sit for about 30 minutes. Used a plastic scraper & got most of it. Used my fingers to get the little balls that just moved around. Takes some patience, but it'll come off. Ventilate! Pat Acetone is virtually harmless unless swallowed. However, don't smoke when you use it. (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/smoke.gif) Handling Acetone is not safe...read the MSDS. |
76-914 |
Mar 17 2011, 05:17 PM
(IMG:style_emoticons/default/agree.gif) A friggin men, that stuff heads straight for your liver. Maybe we can get the good Dr.E to weigh in on this. What's osmosis? Back on track...Body shops also sell a rubber wheel for removing glue/mastic crap but I don't know if it would work on the hardened Wurth's stuff. Anyone?
windforfun |
Mar 17 2011, 05:29 PM
From the MSDS for acetone:
Potential Health Effects: Inhalation: Inhalation of vapors irritates the respiratory tract. May cause coughing, dizziness, dullness, and headache. Higher concentrations can produce central nervous system depression, narcosis, and unconsciousness. Ingestion: Swallowing small amounts is not likely to produce harmful effects. Ingestion of larger amounts may produce abdominal pain, nausea and vomiting. Aspiration into lungs can produce severe lung damage and is a medical emergency. Other symptoms are expected to parallel inhalation. Skin Contact: Irritating due to defatting action on skin. Causes redness, pain, drying and cracking of the skin. Eye Contact: Vapors are irritating to the eyes. Splashes may cause severe irritation, with stinging, tearing, redness and pain. Chronic Exposure: Prolonged or repeated skin contact may produce severe irritation or dermatitis. Aggravation of Pre-existing Conditions: Use of alcoholic beverages enhances toxic effects. Exposure may increase the toxic potential of chlorinated hydrocarbons, such as chloroform, trichloroethane. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:28 PM |
