Engmann fuse panel assembly |
matteyp |
Mar 18 2011, 12:05 PM
Nothing a little JB Weld can't fix... Group: Members Posts: 263 Joined: 8-June 09 From: WA Member No.: 10,450 Region Association: Pacific Northwest |
Hey does anyone have any pics of there fuse panel wired up correctly? Was slightly confused about a couple of the wire locations. Thanks
Matt |
914itis |
Mar 18 2011, 12:08 PM
Hey does anyone have any pics of there fuse panel wired up correctly? Was slightly confused about a couple of the wire locations. Thanks Matt there is really not much to it.. just follow the same sequence. pretty easy and mine included instructions make sure you use the same screws that came out of the old one. if the screw is a bit longer, it may touch the main positive wire and burn it.. ask me hoe I know? (IMG:style_emoticons/default/barf.gif) |
matteyp |
Mar 18 2011, 12:22 PM
Ok here's what I didn't get. I'll try to explain. Do u skip the second contact on the side that's facing the steering column? I believe it's a yellow wire. Also the one of the contacts on the same side, I believe it would be G if your going in order has two contacts and the panel did not have two contacts for that particular one. That's why I wanted to see a couple pics just to make sure I have it all correct. Thanks
Matt |
Cap'n Krusty |
Mar 18 2011, 02:41 PM
The number and location of the terminals is the same. Plug each wire into the terminal corresponding to the one in the old fusebox. If there's a gap, you need to have the gap on the new one.
The Cap'n |
montoya 73 2.0 |
Mar 18 2011, 04:47 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
QUOTE Also the one of the contacts on the same side, I believe it would be G if your going in order has two contacts and the panel did not have two contacts for that particular one Go to Schucks or autozone and get yourself some of those multi plug connectors (single female to double male). Maybe this could work for you? |
Mar 18 2011, 05:30 PM
Go to Schucks or autozone and get yourself some of those multi plug connectors (single female to double male). (IMG:style_emoticons/default/confused24.gif) If the current fusepanel has double connectors, why not just unplug those and re-use them??? (IMG:style_emoticons/default/popcorn[1].gif) |
Cap'n Krusty |
Mar 18 2011, 05:31 PM
A connector came in the package with the panel. Not like that one, but the "Y" type, and it works fine.
The Cap'n |
The number and location of the terminals is the same. Plug each wire into the terminal corresponding to the one in the old fusebox. (IMG:style_emoticons/default/agree.gif) |
montoya 73 2.0 |
Mar 18 2011, 08:01 PM
I agree with you both Andy and Cap'n.
MatteyP, Can you use the existing or included "Y" connectors? |
matteyp |
Mar 19 2011, 12:08 AM
I was assuming the existing y connections on the panel were in there correct locations and shouldnt need to be moved. I figured out I can take them off but didn't know whether or not I should have moved them around
montoya 73 2.0 |
Mar 19 2011, 10:17 PM
Moved them around meaning putting in a different fuse location? I used the piggyback because it's tight in there and the "Y" connector was replaced with the piggyback. I removed from the original and placed on the same fuse accordingly.
Lo-Fi Version | Time is now: 17th May 2024 - 05:24 PM |
