Who sells the rubber Grommets for the engine bulk head fuel lines? |
rick 918-S |
Mar 20 2011, 01:25 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I'm replacing the fuel lines on the Ravenna car with the Chris Foley line set. My Grommets were not salvageable for the engine bay side. Who carries them in stock or what are you guys using? I thought about using a rubber fuel or vacum hose over the stainless line...but... (IMG:style_emoticons/default/confused24.gif)
jmill |
Mar 20 2011, 01:40 PM
I'd bring the beat up one to NAPA or your Flaps. Both should sell them in assorted sizes. Ace Hardware might have them too. I used to buy them there for running wires for car stereos through the firewall. I might even have a bunch left over if you don't come up with any.
silver74insocal |
Mar 20 2011, 01:45 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
im pretty sure Mikey914 does , if not i know pelican does...
Eric_Shea |
Mar 20 2011, 02:40 PM
Robert... also makes stainless lines in the MV section.
They are the same as the brake line grommets as well (the two going through the body to the MC). I asked Pelican and they said they didn't have them. |
ChrisFoley |
Mar 20 2011, 02:50 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I have firewall and engine shelf grommets
type47 |
Mar 20 2011, 03:06 PM
111.957.861
Rotary'14 |
Mar 20 2011, 03:22 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Robert... also makes stainless lines in the MV section. They are the same as the brake line grommets as well (the two going through the body to the MC). I asked Pelican and they said they didn't have them. That's me! Drop me a line if ya need any fuel delivery related stuff. You can see what I offer in the link on my signature. (IMG:style_emoticons/default/biggrin.gif) -Robert |
rick 918-S |
Mar 20 2011, 03:25 PM
jmill |
Mar 20 2011, 05:17 PM
type47 |
Mar 21 2011, 07:19 AM
These are used where the brake fluid supply lines from the reservoir go through the body to the master cylinder and where the fuel line go through the engine shelf near the battery. As you can tell from the number (111.xxx.xxx), they are a VW part and you can probably find them fairly easily from the VW vendors (cip1, bus boys, west coast metric) along with Porsche parts vendors.
dr914@autoatlanta.com |
Mar 21 2011, 08:10 AM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
All of the usual suspects have plenty of both the bulkhead and the engine shelf grommets in stock to compliment Chris's fabulous stainless steel fuel lines.
\ I'm replacing the fuel lines on the Ravenna car with the Chris Foley line set. My Grommets were not salvageable for the engine bay side. Who carries them in stock or what are you guys using? I thought about using a rubber fuel or vacum hose over the stainless line...but... (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Mar 21 2011, 08:39 AM
Robert... also makes stainless lines in the MV section. They are the same as the brake line grommets as well (the two going through the body to the MC). I asked Pelican and they said they didn't have them. That's me! Drop me a line if ya need any fuel delivery related stuff. You can see what I offer in the link on my signature. (IMG:style_emoticons/default/biggrin.gif) -Robert (IMG:style_emoticons/default/icon_bump.gif) I wanted to give Robert a bump for us west coasters. I just installed his set last week. Very quick and easy install. Took 20 min's. I already had the engine and gas tank removed. Good quality and quick shipping. (IMG:style_emoticons/default/beerchug.gif) |
sww914 |
Mar 21 2011, 07:02 PM
All of the usual suspects have plenty of both the bulkhead and the engine shelf grommets in stock to compliment Chris's fabulous stainless steel fuel lines. \ I'm replacing the fuel lines on the Ravenna car with the Chris Foley line set. My Grommets were not salvageable for the engine bay side. Who carries them in stock or what are you guys using? I thought about using a rubber fuel or vacum hose over the stainless line...but... (IMG:style_emoticons/default/confused24.gif) WTF happened to George? |
Lo-Fi Version | Time is now: 17th May 2024 - 04:24 PM |
