Lost an axle today @ 85 MPH, and got to work 5 min late |
jsayre914 |
Mar 21 2011, 10:16 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I am a luck SOB (IMG:style_emoticons/default/rolleyes.gif)
40 min in to my drive to work. Music jammin wind flying im in the fast lane (big trucks all around the place) and WHAM I loose the transmission, still in 5th gear but car is in neutral. And the exhaust is noticeably louder.... I put my signal on to coast 3 lanes as the trucks try to spped up and not let me over (IMG:style_emoticons/default/sad.gif) I am loosing momentum. Finally I see a break and coast onto the shoulder. Kill the engine. Ready to call the towtruck. It was a bad clunk. I look over the car engine transmission when i notice the drivers axle sitting on the heat exchanger (IMG:style_emoticons/default/blink.gif) All four bolts were still there (IMG:style_emoticons/default/beerchug.gif) A nice dent in the top of the heat exchanger. I thread the bolts on by hand and get the allen wrench, tighten everything back up. IN THE RAIN. and my hands are thick black CV grease (IMG:style_emoticons/default/first.gif) Got to work 5 min late. (IMG:style_emoticons/default/shades.gif) p.s. I bought evils saftey bolts and forgot to put the wire in (IMG:style_emoticons/default/slap.gif) |
URY914 |
Mar 21 2011, 10:36 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The joys of 914 ownership. Glad you're OK. (IMG:style_emoticons/default/bye1.gif)
flipb |
Mar 21 2011, 10:40 AM
Senior Member Group: Members Posts: 1,722 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Holy crap! You are so lucky!
You have a rush-hour commute that allows you to go 85mph? In Maryland???????? (IMG:style_emoticons/default/lol-2.gif) |
Cap'n Krusty |
Mar 21 2011, 10:59 AM
In 38 years of 914 CV joint installation, I've had ONE fail bad enough to prevent the car from moving under its own power. Never used safety wire. Must be the fact I do it right, every time. Or maybe not ........................
Jakeodoule |
Mar 21 2011, 12:16 PM
Member Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
In 38 years of 914 CV joint installation, I've had ONE fail bad enough to prevent the car from moving under its own power. Never used safety wire. Must be the fact I do it right, every time. Or maybe not ........................ (IMG:style_emoticons/default/WTF.gif) where's "The Cap'n" |
913B |
Mar 21 2011, 12:31 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Just curious were the bolts switched over to the allan ones or the original 12 point ones.
P.s. Glad you and the 14 was ok. |
dw914er |
Mar 21 2011, 12:50 PM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
crazy... but I'm glad it worked out and you were able to keep the 914 running.
jsayre914 |
Mar 21 2011, 01:12 PM
Just curious were the bolts switched over to the allan ones or the original 12 point ones. P.s. Glad you and the 14 was ok. They are the Evil allen bolts . I was just forgot to put the wire in. (IMG:style_emoticons/default/rolleyes.gif) |
Woody |
Mar 21 2011, 03:33 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Torque wrench is your friend. (IMG:style_emoticons/default/shades.gif)
montoya 73 2.0 |
Mar 21 2011, 03:42 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
In 38 years of 914 CV joint installation, I've had ONE fail bad enough to prevent the car from moving under its own power. Never used safety wire. Must be the fact I do it right, every time. Or maybe not ........................ (IMG:style_emoticons/default/WTF.gif) where's "The Cap'n" (IMG:style_emoticons/default/agree.gif) Who are you and where's the real Cap'n? |
jimtab |
Mar 21 2011, 05:16 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
For those of us in the "great unwashed" group....just what is the torque setting, I just wind 'em up until the wrench handle begins to bend.... (IMG:style_emoticons/default/rolleyes.gif)
orange914 |
Mar 21 2011, 06:21 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
In 38 years of 914 CV joint installation, I've had ONE fail bad enough to prevent the car from moving under its own power. Never used safety wire. Must be the fact I do it right, every time. Or maybe not ........................ or maybe... jaysayre914, don't you work in a "head shop"... just sayin' (IMG:style_emoticons/default/stirthepot.gif) |
pauldunn |
Mar 21 2011, 06:51 PM
dudeface Group: Members Posts: 41 Joined: 9-February 11 From: Arizona Member No.: 12,687 Region Association: Southwest Region |
I cant tell you how many time that has happened to me in my baja bug. way too many times!!!! even once the left rear trans bolt came out which left the driver side of the trans resting on the cv joint. found the bolt, walked 5 miles to buy a wrench and put it back in with no problems. joys of owning old cars...
76-914 |
Mar 21 2011, 10:20 PM
In 38 years of 914 CV joint installation, I've had ONE fail bad enough to prevent the car from moving under its own power. Never used safety wire. Must be the fact I do it right, every time. Or maybe not ........................ and being the consumate professional I'll bet you torque them. I say this after retightening mine several times I read about using all new parts and torqueing them. I was amazed at how under torqued I had done it before. It's scary tight. |
VaccaRabite |
Mar 22 2011, 06:06 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Well, that was probably the sound you were hearing.
I'm glad you were able to get it fixed roadside. If you are reading this, I'm still sick so you probably don't want me helping tonight. (IMG:style_emoticons/default/sad.gif) Just my luck finally having a week off and being sick. I'm not getting much of anything done! Zach |
jsayre914 |
Mar 22 2011, 06:34 AM
Well, that was probably the sound you were hearing. I'm glad you were able to get it fixed roadside. If you are reading this, I'm still sick so you probably don't want me helping tonight. (IMG:style_emoticons/default/sad.gif) Just my luck finally having a week off and being sick. I'm not getting much of anything done! Zach Thanks anyway Zach, I believe the sounds i was hearing was a combo of loose cv, bad bearing, and exhaust leak. All will be fixed tommorow (IMG:style_emoticons/default/cheer.gif) Good news is i can turn the stereo up lound enough that all the sounds are gone (IMG:style_emoticons/default/laugh.gif) |
Dr Evil |
Mar 22 2011, 08:26 AM
RJMII makes the kits now. For those that have not needed them good. For those that argue that they are unnecessary, all I say is:
I have been driving cars for many years and never needed my air bag..... (IMG:style_emoticons/default/rolleyes.gif) Cheap insurance that works. Period. |
Dr Evil |
Mar 22 2011, 08:27 AM
Torque is 30 ft/lb
jsayre914 |
Mar 24 2011, 11:01 AM
Car is in the shop gettin the rear bearings done.
Tony checked the axle for me and noticed that i lost the cv gasket and both pins that line it up. (IMG:style_emoticons/default/slap.gif) He is also going to fix the horrible exhaust leak the axle caused (IMG:style_emoticons/default/wub.gif) |
Mar 24 2011, 11:13 AM
RJMII makes the kits now. For those that have not needed them good. For those that argue that they are unnecessary, all I say is: I have been driving cars for many years and never needed my air bag..... (IMG:style_emoticons/default/rolleyes.gif) Cheap insurance that works. Period. I did consider these, the wired ones, for a bit....just cause I too lost an axle once. then I spent the big dollars and bought new washers and a gasket. Simple todo...and it has held for 10 years...no issues. Seems all my cars have CV joints now and no wires. Probably just using the right parts and the right torque is all that is needed. I think alot of us may re-use the washers and they are really one time only use. The wires are insurance, but I always suspect how much potential weakness the system has created in the head of the bolt...considering how hard I have had to get on these sometimes with vice grips...I have been worried about two holes becoming an issue... Dunno, if I ever have a problem again, I will probably go for the wire, or nuts on the back... That comes from a guy that is full of Sh#$ so keep that in mind...lots of people would agree with that statement about me.... (IMG:style_emoticons/default/smile.gif) I have owned over 20 aircooled VW/Porsche cars. I have worked on them non professionally, total shade tree for 30 plus years now. All of them have CV joints....well most of them...some had swing axles (which I hate) In all those cars, in and out with the transmissions....none have failed EXCEPT the 914. Must be more vibration or stress on something. I am no Cap'n, nor would I ever claim to be. Certainly have my days that I would respond in the same Crusty like manner...but as I get older I choose to walk away from the site at that point... (IMG:style_emoticons/default/smile.gif) RIch |
Lo-Fi Version | Time is now: 17th May 2024 - 02:39 PM |
