Tyvek? |
Tyvek? |
KaptKaos |
Mar 21 2011, 10:00 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
They wrap buildings in this stuff for the vapor barrier.
I recently pulled a door panel, and the plastic, I think, was stock. I was thinking of using tykek to replace it. Thoughts? |
Mike Bellis |
Mar 21 2011, 10:05 PM
Should work just as good as a glad bag. But stronger. Tyvek will keep out moisture and wind...
Mar 21 2011, 10:36 PM
Should work just as good as a glad bag. But stronger. Tyvek will keep out moisture and wind... (IMG:style_emoticons/default/agree.gif) The stock plastic was both a moisture barrier and a way to keep the wind noise and drafts down ... (IMG:style_emoticons/default/smile.gif) |
Rand |
Mar 21 2011, 10:39 PM
And then you can use sheetrock instead of door panels, put some mud on there with a nice texture, paint it eggshell white.... (IMG:style_emoticons/default/tongue.gif) j/k
Might even cut noise levels a little more? If you have some extra on hand give it a try. We wanna see. (IMG:style_emoticons/default/smile.gif) |
Tom_T |
Mar 21 2011, 11:29 PM
IIRC Tyvek is a more "breathable" membrane made for wood framing, so IMHO you'd be better off using standard poly-sheet "Visquene" as used under the concrete slab floors. Visquene is also available in roll stock & various thicknesses. 10-12 mils would suffice I would think.
URY914 |
Mar 22 2011, 05:12 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
We spell it "Visqueen" down here and I agree it would be better.
Mark Henry |
Mar 22 2011, 06:16 AM
I agree. Tyvec is not a vapor barrier, it may be moisture resistant but it's not moisture proof.
You're looking at the wrong side of the studwall...6ml poly vapor barrier will do a better job and is what I've used for years in VW bug doors. |
76-914 |
Mar 22 2011, 10:09 AM
What's all this moisture proofing talk? (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/laugh.gif) Better block off those drain slots and silicone up all the window squegees, felt strips, door handles and block off that key hole, too!
Mark Henry |
Mar 22 2011, 10:32 AM
I know you're joking, but the main purpose of the VB is so your door panels won't rot off. The backs are basically paper (masonite) and will turn into warped crap in no time flat without a VB.
Mar 22 2011, 04:00 PM
tyvek is a wind barrier.
It is designed to let moisture escape from the building. By design it will allow moisture to go through and wreck your door panels from behind. To do it right, use plastic. Rich |
Drums66 |
Mar 22 2011, 04:39 PM
By design it will allow moisture to go through and wreck your door panels from behind. Rich .......It sure will! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
G e o r g e |
Mar 22 2011, 05:23 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
i've got stego you can use.
Rand |
Mar 22 2011, 05:55 PM
Question for the Tyvek experts... I thought it was a moister/vapor barrier?
QUOTE Sealing the building envelope also helps protect your home against bulk water intrusion and air-transported moisture. Quoted from their site. http://www2.dupont.com/Tyvek_Weatherizatio...homeowners.html So you're saying "air-transported moisture" doesn't really mean vapor proof, just water resistant? |
Mark Henry |
Mar 22 2011, 06:30 PM
Question for the Tyvek experts... I thought it was a moister/vapor barrier? QUOTE Sealing the building envelope also helps protect your home against bulk water intrusion and air-transported moisture. Quoted from their site. http://www2.dupont.com/Tyvek_Weatherizatio...homeowners.html So you're saying "air-transported moisture" doesn't really mean vapor proof, just water resistant? Yes, the best analogy I can come up with is think of a water resistant watch compared to a water proof watch. Quote from your link: QUOTE DuPont™ Tyvek® reduces the movement of air into your home and also helps keep water (from driving rain, for example) out of your walls. DuPont™ Tyvek® can breathe too. That means that if moisture does get inside you walls DuPont™ Tyvek® lets it pass through to the outside. Helping to keep air and water out; letting moisture vapor pass through—it's the perfect way to keep you comfortable year round. |
drew365 |
Mar 22 2011, 06:39 PM
Tyvek will allow vapor (gas) moisture to travel through it in either direction but stops liquid water. This is beneficial to allow a homes wall system to breathe in both directions as the climate changes from winter to summer without a buildup of condensation which could dry rot the framing.
Plastic will stop both vapor and liquid moisture, but could lead to condensation which could create rust on the inner door. Since the inner door panels aren't sealed, I wonder how much protection the plastic is really providing. But, if vapor damage to the inside of the door panel is a bigger problem than rust damage from condensation, I'd stick with the plastic. Seems like a toss up to me. |
Rand |
Mar 22 2011, 06:44 PM
Interesting. I thought it was designed to prevent all moisture from getting in (including vapor, as I thought they meant by "air-transported moisture") but to allow vapor to escape... One-way. Which would mean it would matter which side you faced outward.
If it actually allows vapor to pass both ways, obviously it's not good for the door panel application. Good discussion. |
Krieger |
Mar 22 2011, 06:49 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
This is not to code.
drew365 |
Mar 22 2011, 06:59 PM
The amount of vapor that is allowed to travel through any weather barrier is calculated as a perm rating. Tyvek has one of the highest perm ratings at 28, building paper about 6, plastic 0. If Tyvek only allowed vapor to travel in one direction you'd risk condensation and mold problems during part of the year. I'm still not saying it's the best answer for a 914 door, I think that would take some testing to determine. But, if you want to stop vapor, use plastic.
Rand |
Mar 22 2011, 07:04 PM
I think the real question is, would contractors pay all the 914world members for their used door plastic so they could wrap a building and save money?
(IMG:style_emoticons/default/tongue.gif) Sounds like it's equally silly to use anything other than plastic in our doors. Kinda like sheetrock mud vs bondo. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:41 PM |
