Relay boards, Difference between /6-/4 |
RiqueMar |
Mar 23 2011, 08:32 AM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Found is relay board yesterday, and I think its a /6 type, because it has less relays? If I remember correctly, the /4 has 4 spots for relays?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1300860420.1.jpg) |
SLITS |
Mar 23 2011, 09:02 AM
You are correct Bugle Boy ....
/6 relay board has 14 pin main body harness connector and 14 pin engine harness connector. Less relays, somewhat different layout, etc /4 relay board has 14 pin main body harness connector and 12 pin engine harness connector. More relays, etc ...... Just use the /4 on your car and match function for the wires on the engine harness. Unless .......... |
RiqueMar |
Mar 23 2011, 09:10 AM
Unless? The suspence is killing! (IMG:style_emoticons/default/biggrin.gif)
You didn't fall asleep on me, did you Grandpa? (IMG:style_emoticons/default/yellowsleep[1].gif) |
Mar 23 2011, 10:38 AM
What's up with your father's six?
RiqueMar |
Mar 23 2011, 11:17 AM
Slits: For my 2,7 would it be better to use the /6 relay board or the /4. I have yet to really understand wiring, so I'm clueless. What's up with your father's six? You hit the nail on the head Mark, that's what I've been saying! At least he is finally decided on an engine, the 2.2S w/ Carbs. That only took about a year (IMG:style_emoticons/default/yellowsleep[1].gif) You wouldn't believe how many times he went from a 3.6, to a 3.2 w Carbs, then a 3.2 w/ direct ignition or PMOs. He even threw out the idea of a 3.0 SC Engine w/ Zeniths like I was gonna do. (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/ar15.gif) Ive been trying to get him on it, but he is too busy in his Ferrari world. I must say, it's pretty cool though. He bought a 360 Challenge Stradale and is converting all the brakes, suspension, interior into his 360 Spyder. |
Elliot Cannon |
Mar 23 2011, 12:18 PM
Unless? The suspence is killing! (IMG:style_emoticons/default/biggrin.gif) You didn't fall asleep on me, did you Grandpa? (IMG:style_emoticons/default/yellowsleep[1].gif) Slits isn't being suspenceful. He just doesn't know what he's talking about. (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/av-943.gif) |
RiqueMar |
Mar 23 2011, 05:24 PM
Slits isn't being suspenceful. He just doesn't know what he's talking about. (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/stirthepot.gif) Does he ever? |
SLITS |
Mar 23 2011, 05:43 PM
Ha ... yonug farts and old UPS pilots .... what a combo
The only benefit to the /6 relay board would be the raw fuel injection into the carbs for cold startup .... nice fire if it backfires. You would need the original air cleaner with the spray tubes and run it. You would also need to acquire the proper relays ... I have a pic somewhere of it. Other than the above, the function would be the same to me. I used the /4 with the /4 engine harness and, following a wiring diagram, matched function for the wires needed. I even used the fuel pump relay to fire the fuel pump. Wanna spend more money then use the /6 and acquire a /6 engine harness. Others do away with the relay board entirely ... there are threads on this ... and eventually the "real" experts will chime in**** **** that doesn't include you Elleyot ............ Oh, the "unless" is if you want to join the pinky lifting, gold chain, whine and cheese crowd. |
windforfun |
Mar 23 2011, 05:52 PM
Senior Member Group: Members Posts: 1,789 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
It looks like either one will cook your battery if you use the old OEM voltage regulator. Whatever.
McMark |
Mar 23 2011, 06:10 PM
If you decide you're not going to use it, let me know. (IMG:style_emoticons/default/wavey.gif)
Elliot Cannon |
Mar 23 2011, 07:05 PM
Ha ... yonug farts and old UPS pilots .... what a combo The only benefit to the /6 relay board would be the raw fuel injection into the carbs for cold startup .... nice fire if it backfires. You would need the original air cleaner with the spray tubes and run it. You would also need to acquire the proper relays ... I have a pic somewhere of it. Other than the above, the function would be the same to me. I used the /4 with the /4 engine harness and, following a wiring diagram, matched function for the wires needed. I even used the fuel pump relay to fire the fuel pump. Wanna spend more money then use the /6 and acquire a /6 engine harness. Others do away with the relay board entirely ... there are threads on this ... and eventually the "real" experts will chime in**** **** that doesn't include you Elleyot ............ Oh, the "unless" is if you want to join the pinky lifting, gold chain, whine and cheese crowd. Holy shite!! Do you suppose he really DOES know what he's talking about?? (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/idea.gif) NAAAAAAAHHHH (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/biggrin.gif) |
SLITS |
Mar 23 2011, 07:27 PM
Ha ... yonug farts and old UPS pilots .... what a combo The only benefit to the /6 relay board would be the raw fuel injection into the carbs for cold startup .... nice fire if it backfires. You would need the original air cleaner with the spray tubes and run it. You would also need to acquire the proper relays ... I have a pic somewhere of it. Other than the above, the function would be the same to me. I used the /4 with the /4 engine harness and, following a wiring diagram, matched function for the wires needed. I even used the fuel pump relay to fire the fuel pump. Wanna spend more money then use the /6 and acquire a /6 engine harness. Others do away with the relay board entirely ... there are threads on this ... and eventually the "real" experts will chime in**** **** that doesn't include you Elleyot ............ Oh, the "unless" is if you want to join the pinky lifting, gold chain, whine and cheese crowd. Holy shite!! Do you suppose he really DOES know what he's talking about?? (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/idea.gif) NAAAAAAAHHHH (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/biggrin.gif) Well, I can spread bullshit deeper than your boots. (IMG:style_emoticons/default/stromberg.gif) |
RiqueMar |
Mar 23 2011, 07:46 PM
Oh, the "unless" is if you want to join the pinky lifting, gold chain, whine and cheese crowd. You forgot the to include the 'Salmon Shirt, Cayenne driver' in that description (IMG:style_emoticons/default/sunglasses.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:26 PM |
