Gear maker, In Australia |
Randal |
Mar 23 2011, 01:20 PM
Done a bunch of searches to find the name of the firm that makes gears for 914 transmissions, but can't find the posting. Anyone remember the name of the company. Thanks. |
brant |
Mar 23 2011, 01:23 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I don't think they sell direct
but I remember carquipt has had them make 904shafts, etc in the past If you only want the name you might call tom at carquipt? b |
Randal |
Mar 23 2011, 03:07 PM
I don't think they sell direct but I remember carquipt has had them make 904shafts, etc in the past If you only want the name you might call tom at carquipt? b Thanks. I saw the name on some posting here and saved it in favorites, but alas it has disappeared. (IMG:style_emoticons/default/sad.gif) |
jmmotorsports |
Mar 23 2011, 05:38 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
I bought a 10:31 ring and pinion set from California Motorsports that was made by that company. I think the name is Albins or something close to that. Jerry |
Randal |
Mar 23 2011, 10:38 PM
I bought a 10:31 ring and pinion set from California Motorsports that was made by that company. I think the name is Albins or something close to that. Jerry Thanks. http://www.albinsgear.com.au/index.php is the website. I've emailed them. |
edwin |
Mar 24 2011, 07:25 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
Hi there
Just so happens that I live in the same city they are based in I did work experience there back in high school and it is a really neat setup Let us know if you have any dramas as I know the owners if you need Cheers Edwin |
ConeDodger |
Mar 24 2011, 09:01 AM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I thought I heard Guard was going to make gears? 915 and G50 only???
Randal |
Mar 24 2011, 03:37 PM
I heard back from Albinsgear on the 904 mainshafts.
Price per shaft is – AUD$1225.50 or about $1,240 US. Distributor in the USA is California Motorsports (roger@californiamotorsports.net). Last company to buy a bunch of the shafts was Carqiup, who might have some. I'll have to check with these companies to find out what gears they have in stock and the pricing. |
J P Stein |
Mar 24 2011, 03:51 PM
As I understand it, Carquip has bought Gaurd. There is a guy over on Pelican....Matt Monsen(sp?) who is involved in some capacity.
brant |
Mar 24 2011, 04:01 PM
I heard back from Albinsgear on the 904 mainshafts. Price per shaft is – AUD$1225.50 or about $1,240 US. Distributor in the USA is California Motorsports (roger@californiamotorsports.net). Last company to buy a bunch of the shafts was Carqiup, who might have some. I'll have to check with these companies to find out what gears they have in stock and the pricing. what gears are you looking for? |
Randal |
Mar 24 2011, 04:52 PM
Randal |
Mar 24 2011, 04:58 PM
I heard back from Albinsgear on the 904 mainshafts. Price per shaft is – AUD$1225.50 or about $1,240 US. Distributor in the USA is California Motorsports (roger@californiamotorsports.net). Last company to buy a bunch of the shafts was Carqiup, who might have some. I'll have to check with these companies to find out what gears they have in stock and the pricing. what gears are you looking for? As soon as I run the car on the dyno I'll be making decisions on the gears. I'll likely be changing second gear and possibly third. Have to see the dyno run first to know which. Problem is that first is only good to heat up the tires and shift to second. Stock second is a bit short, but I was only running to 6K. My third is an M, but that might need to change depending upon the dyno run as well. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:19 PM |
