1873 lb. MX5 |
1873 lb. MX5 |
Eric_Shea |
Mar 23 2011, 10:41 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
PlaysWithCars |
Mar 25 2011, 11:49 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Those are some impressive numbers. Yeah, fun would be one way to describe it.
J P Stein |
Mar 26 2011, 08:16 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
What a porker!
grantsfo |
Mar 26 2011, 09:34 AM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Not bad for a production car based endurance racer with touring car cage. That little 2.0 must scream to make 275 hp. Could you imagine a 275 2 liter T4?
Randal |
Mar 26 2011, 10:52 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Not bad for a production car based endurance racer with touring car cage. That little 2.0 must scream to make 275 hp. Could you imagine a 275 2 liter T4? CB Performance has been putting turbos on T1 motors for a long time, with power outputs of 275hp or greater. They use them on sand buggies and the word is that they hold up well, so might not be a stretch to support a T4. http://www.cbperformance.com/images/2332turbo.jpg |
grantsfo |
Mar 29 2011, 07:18 AM
Not bad for a production car based endurance racer with touring car cage. That little 2.0 must scream to make 275 hp. Could you imagine a 275 2 liter T4? CB Performance has been putting turbos on T1 motors for a long time, with power outputs of 275hp or greater. They use them on sand buggies and the word is that they hold up well, so might not be a stretch to support a T4. http://www.cbperformance.com/images/2332turbo.jpg That Mazda Miata 275 hp 2.0 liter is naturally aspirated. I think by most calculations for turbos assume double the displacement. So it takes 4.6 liters of T1 motor to equal a little 2.0 Miata motor. (IMG:style_emoticons/default/shades.gif) I think the most I have seen from a NA 2.0 t4 is about 200 hp. That same Mazda 2.0 blown could crank out north of 450 hp! This post has been edited by grantsfo: Mar 29 2011, 07:24 AM |
grantsfo |
Mar 29 2011, 07:42 AM
What a porker! JP, I bet that same car in AX trim could be dropped to 1600 lbs easily. Touring cars still carry lights, metal body panels, lots of cage, safety system, windshields, lots of gauges and monitoring systems. After owning a MX5 I have always though it would be a hoot to turn into a prepared car. They have better suspension than old Miatas and that 2.0 motor holds tons of potential with engine resources easily available to get tons of hp from that little ford motor. |
Randal |
Mar 30 2011, 10:44 PM
Not bad for a production car based endurance racer with touring car cage. That little 2.0 must scream to make 275 hp. Could you imagine a 275 2 liter T4? CB Performance has been putting turbos on T1 motors for a long time, with power outputs of 275hp or greater. They use them on sand buggies and the word is that they hold up well, so might not be a stretch to support a T4. http://www.cbperformance.com/images/2332turbo.jpg That Mazda Miata 275 hp 2.0 liter is naturally aspirated. I think by most calculations for turbos assume double the displacement. So it takes 4.6 liters of T1 motor to equal a little 2.0 Miata motor. (IMG:style_emoticons/default/shades.gif) I think the most I have seen from a NA 2.0 t4 is about 200 hp. That same Mazda 2.0 blown could crank out north of 450 hp! Are you saying that T4's aren't modern engines Grant? |
Lo-Fi Version | Time is now: 15th May 2024 - 01:08 PM |
