Converting to Carbs, What is a good setup for F Pump and Pressure |
falconfp2001 |
Mar 24 2011, 02:57 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I'm gonna setup dual carbs and would like to use the stock Fuel Pump but I'm trying to figure out how to setup the Pressure Regulators.
My idea is to keep my return line to the gas tank and just have two regulators. One before the carbs and another after. Anyone have a good suggestion? Thanks |
jmill |
Mar 24 2011, 04:02 PM
If I were you I'd save a ton of cash and get a CB Performance pump which is internally regulated at 3 1/2 psi. Place it in the front below the tank with a filter before it and place a filter in the engine compartment before the carbs.
With that said, I've run a holley pump and a regulator and it worked fine. If you look at the price of the pump, regulator and gauge and compare it to the cost of the CB pump, your money ahead with the CB. BTW - Holley makes a one in two out regulator. |
dirk9141973 |
Mar 24 2011, 04:29 PM
Unregistered |
(IMG:style_emoticons/default/idea.gif) Ok think this out little bit ? Sell the old working fuel pump on e-bay $ 100 +/- purchase correct fuel pump $ 75 relocate fuel pump to front under gas tank use the return fuel line a wireing path and take your wife to dinner with the $25 !!
jjackson |
Mar 24 2011, 05:04 PM
Member Group: Members Posts: 219 Joined: 5-October 10 From: maumelle, arkansas Member No.: 12,246 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Ran CB pump for years on several motor combinations.Never had a problem.Not a fan of facet pumps.J
jt914-6 |
Mar 24 2011, 05:15 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
As has been said....get a CB pump up front with a filter between the tank and pump...one near the carbs....Holly regulator with gauge.....here's my Holly reg./gauge....although it's on a six the same would apply for a dual carb four....
Cap'n Krusty |
Mar 24 2011, 06:10 PM
We have a name for people who use the stock FI pump and a regulator with carburetors. We call 'em "fire victims". It's in your best interest not to become one.
The Cap'n |
moparrob |
Mar 24 2011, 08:53 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
I went with the Holley 125 low pressure pump and their matching regulator. Check Summit or Jegs for best prices.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1301021620.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1301021620.2.jpg) Not cheap but dependable and quiet. |
Elliot Cannon |
Mar 24 2011, 08:58 PM
CB Performance rotary pump. "Works fine, lasts a long time". (With appologies to Pratt and Whitney). (IMG:style_emoticons/default/laugh.gif)
Elliot Cannon |
Mar 24 2011, 09:00 PM
We have a name for people who use the stock FI pump and a regulator with carburetors. We call 'em "fire victims". It's in your best interest not to become one. The Cap'n (IMG:style_emoticons/default/agree.gif) Totally. Hell, I have to agree with the Cap'n. He's been working on these things for 75 years! (IMG:style_emoticons/default/first.gif) |
jmill |
Mar 24 2011, 09:18 PM
Very sweet setup. I like the billet pump. I'll have to keep this in mind when I get the 6 running. At 110 GPH it's overkill for a stockish 4 cylinder. |
NJ914Guy |
Mar 24 2011, 09:28 PM
Member Group: Members Posts: 150 Joined: 30-December 10 From: Deptford, NJ Member No.: 12,546 Region Association: MidAtlantic Region |
My shop is just wrapping up my 1973 2.0. Went with dual Weber 40 IDF carbs with Redline linkage and manifolds + CB Performance 40mm velocity stacks. We are running 3psi with a Facet fuel pump up front under the gas tank mounted on rubber stops and a Holly fuel regulator in the engine compartment. Also did full stainless fuel lines with dual filters, one at the pump and a second before the carbs. Shakedown runs were today and she is running excellent. Also did the throttle pedal bushings and a new throttle cable. Good luck with your project.
jmill |
Mar 24 2011, 09:45 PM
Had a Facet on a dual carbed high reving 1914 cc VW motor. The Facet couldn't supply the needed fuel volume at sustained high RPM. The $64 for a CB rotary was a lot cheaper than burning up my engine. I would be surprised if you didn't have similar issues with a 2 liter.
falconfp2001 |
Mar 25 2011, 02:10 AM
Think I like this Regulator
I also like the Holley pumps but they are pretty steep in price. Attached image(s) |
NJ914Guy |
Mar 25 2011, 05:33 AM
Yep, heard good and bad about the Facet and CB Rotary pumps. My Facet was making about 7-8psi, hence the regulator to neck it down to three. For what it's worth, she ran great on some back roads and also a 20min highway run at up to 85mph.
I understand that the Facets can click and sound loud and that the CBs have a tendency to make you reach for your AAA card and walk home. We had the electric fuel pressure gauge hooked up and got consistent 3psi in conjunction with the Holley regulator during our test drive. Also, once primed and flat four running, I can't hear the pump running. |
jimkelly |
Mar 25 2011, 05:47 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
would 30 gph be ok for my V8 ??
Root_Werks |
Mar 25 2011, 07:06 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
jimkelly |
Mar 25 2011, 01:17 PM
ok - i should have said - i have this friend who parks his V8 914 in my garage : (
maybe i need this ... http://www.jegs.com/i/Holley/510/12-802-1/10002/-1 jim |
McMark |
Mar 25 2011, 03:58 PM
I prefer to go with a higher end pump and a quality regulator. Perhaps it's false security, but I do feel better about being able to adjust my fuel pressure.
Ericv1 |
Mar 25 2011, 04:11 PM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
Yep, heard good and bad about the Facet and CB Rotary pumps. My Facet was making about 7-8psi, hence the regulator to neck it down to three. For what it's worth, she ran great on some back roads and also a 20min highway run at up to 85mph. I understand that the Facets can click and sound loud and that the CBs have a tendency to make you reach for your AAA card and walk home. We had the electric fuel pressure gauge hooked up and got consistent 3psi in conjunction with the Holley regulator during our test drive. Also, once primed and flat four running, I can't hear the pump running. That's a real world scenario. I'm sorting out my six conversion and I bought a CB pump at the beginning of last year. On Wednesday evening (this week) My fuel pump went out about 9 tenths of a mile from my house. I was on a hill otherwise I would have pushed it home. The pump was only used maybe 10-15 times in small intervals to help tune the carbs. I was hoping it was a relay. I pulled both relays out of the headlights and replaced them on the rear circuit board but it was a no go. I can't be to pissed off because it was only $60. But, now I have to pull the gas tank and replace it again. |
nathansnathan |
Mar 25 2011, 04:12 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
From my experience with rotary pumps, they say they are high volume low pressure, that they will give you 3 1/2 psi unregulated, but the actual is more like 5 or so, more than enough to get by a lot of inlet valves. I've got a carter rotary pump and the holley regulator, plus vdo in compartment gauge.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-11782-1301091217.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-11782-1301091219.2.jpg) That's my type 4-engined bus there, as the 914 is fuel injected still. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:57 PM |
