EFI for 1k, programable |
r_towle |
Mar 27 2011, 03:00 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Does it exist yet?
Ideally, 1k for ITB's, EFI and harness. Anyone...and no Megasquirt please.. Looking for something to start with...then like any good drug, get hooked and pay more to play. Rich |
jd74914 |
Mar 27 2011, 06:36 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
You can buy a number of entry level ECU's with harnesses for <$1k, but ITB's are definately not going to come in under that mark. ITB's are expensive enough that In fact, unless you adapter motorcycle throttle bodies, I am condident you would spend more than that piecing together a MS system with them. Off the top of my head, Adaptronic, DTA, Performance Electronics, and Spectre (EMS Pro) all offer resonably priced ECU's. Also, at the pricepoint you are looking at, I really wouldn't discount pre-assembled MS units or Microsquirts. The last MS product I played with was 2.5+ years ago and I wasn't super impressed by the quality, but from what I have seen of late, they seem to be maturing into extremely nice products. Part of my disatisfaction was post likely related to my inexperience. Right now I have friends whose DD's run with them. I do like the Adaptronic e420C, the one on our racecar has been bulletproof, its only limitation is the lack of individual cylinder trim, and a slightly different correction tabel setup. |
JamesM |
Mar 27 2011, 09:33 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I am not to familar with the others but from what i remember the Spectre EMS pro IS a Megasquirt 1 based ECU. Whenever you see a low cost ECU look really close, good change it is megasquirt based.
(IMG:style_emoticons/default/agree.gif) You can buy a number of entry level ECU's with harnesses for <$1k, but ITB's are definately not going to come in under that mark. ITB's are expensive enough that In fact, unless you adapter motorcycle throttle bodies, I am condident you would spend more than that piecing together a MS system with them. Off the top of my head, Adaptronic, DTA, Performance Electronics, and Spectre (EMS Pro) all offer resonably priced ECU's. Also, at the pricepoint you are looking at, I really wouldn't discount pre-assembled MS units or Microsquirts. The last MS product I played with was 2.5+ years ago and I wasn't super impressed by the quality, but from what I have seen of late, they seem to be maturing into extremely nice products. Part of my disatisfaction was post likely related to my inexperience. Right now I have friends whose DD's run with them. I do like the Adaptronic e420C, the one on our racecar has been bulletproof, its only limitation is the lack of individual cylinder trim, and a slightly different correction tabel setup. |
Lo-Fi Version | Time is now: 20th May 2024 - 04:02 AM |
