EFI for 1k, programable |
r_towle |
Mar 27 2011, 03:00 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Does it exist yet?
Ideally, 1k for ITB's, EFI and harness. Anyone...and no Megasquirt please.. Looking for something to start with...then like any good drug, get hooked and pay more to play. Rich |
jd74914 |
Mar 27 2011, 06:36 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
You can buy a number of entry level ECU's with harnesses for <$1k, but ITB's are definately not going to come in under that mark. ITB's are expensive enough that In fact, unless you adapter motorcycle throttle bodies, I am condident you would spend more than that piecing together a MS system with them. Off the top of my head, Adaptronic, DTA, Performance Electronics, and Spectre (EMS Pro) all offer resonably priced ECU's. Also, at the pricepoint you are looking at, I really wouldn't discount pre-assembled MS units or Microsquirts. The last MS product I played with was 2.5+ years ago and I wasn't super impressed by the quality, but from what I have seen of late, they seem to be maturing into extremely nice products. Part of my disatisfaction was post likely related to my inexperience. Right now I have friends whose DD's run with them. I do like the Adaptronic e420C, the one on our racecar has been bulletproof, its only limitation is the lack of individual cylinder trim, and a slightly different correction tabel setup. |
CG-914 |
Mar 27 2011, 07:09 PM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) You can buy a number of entry level ECU's with harnesses for <$1k, but ITB's are definately not going to come in under that mark. ITB's are expensive enough that In fact, unless you adapter motorcycle throttle bodies, I am condident you would spend more than that piecing together a MS system with them. Off the top of my head, Adaptronic, DTA, Performance Electronics, and Spectre (EMS Pro) all offer resonably priced ECU's. Also, at the pricepoint you are looking at, I really wouldn't discount pre-assembled MS units or Microsquirts. The last MS product I played with was 2.5+ years ago and I wasn't super impressed by the quality, but from what I have seen of late, they seem to be maturing into extremely nice products. Part of my disatisfaction was post likely related to my inexperience. Right now I have friends whose DD's run with them. I do like the Adaptronic e420C, the one on our racecar has been bulletproof, its only limitation is the lack of individual cylinder trim, and a slightly different correction tabel setup. are there links for these? |
Lo-Fi Version | Time is now: 9th May 2024 - 01:50 PM |
