EFI for 1k, programable |
r_towle |
Mar 27 2011, 03:00 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Does it exist yet?
Ideally, 1k for ITB's, EFI and harness. Anyone...and no Megasquirt please.. Looking for something to start with...then like any good drug, get hooked and pay more to play. Rich |
914forme |
Mar 30 2014, 08:47 AM
If your using Carbs, epoxy all the holes except the idle bypasses. Gut them make the bores as clean as you can. Do not forgot that you ned a vacuum tap in each bore, an build a vacuum manifold so your MAP can pickup a more stable signal.
Carbs are a great way to build these, you just don't need all the junk. Plan and simple its way easier to do a manifold and a single TB. Key is go out and have fun, and learn something new. |
Lo-Fi Version | Time is now: 9th May 2024 - 04:51 AM |
