Flat towing, not since 1973 |
Elliot Cannon |
Mar 27 2011, 06:28 PM
It's been a long time since I towed my 1965 bug behind my Mothers 1964 ImpalaSS. U Haul bumper hitch and towbar. (IMG:style_emoticons/default/laugh.gif) I learned that day you can't back up while flat towing a car. (IMG:style_emoticons/default/confused24.gif) Any suggestions? I need to go 30 miles. Car's in neutral, battery desconnected, ignition switch on to keep steering wheel from locking, parking brake off. What'd I forget?
Cheers, Elliot Attached thumbnail(s) |
Elliot Cannon |
Mar 27 2011, 06:30 PM
Two more.
AZ914 |
Mar 27 2011, 06:34 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I don't think you forgot anything. I've flat towed mine a few times. Can't backup because the wheel will turn the way you don't want it to.
Make sure the door is unlocked so you can get in there quick if necessary. |
URY914 |
Mar 27 2011, 06:44 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,883 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You may want to cover the cars hood somehow so rocks coming off the trucks tires don't chip that pretty black paint.
Elliot Cannon |
Mar 27 2011, 06:45 PM
Thanks Jason. The doors don't lock anyway so... (IMG:style_emoticons/default/laugh.gif)
DanT |
Mar 27 2011, 07:00 PM
Safety chains need to attach to the car. With mine I attached to the tow bracket
With some large chain link connecters Your draw bar should be low enough so the tow bar is flat. With it pitched up at the hitch head, every time you hit the brakes the 914 will be pushing up instead of straight forward into The tow vehicle. |
AZ914 |
Also, I see your magnet light wire over the mirror etc. I've done it that way and at freeway speeds the thing vibrates and will scuff the clear coat (or paint). IF there is any way you can rig it so the wires don't touch the paint, do it. (and then tell me how you did it...) (IMG:style_emoticons/default/smile.gif)
DanT |
Mar 27 2011, 07:06 PM
For wiring I hard wired mine with one way diodes, using the stock 914 turn and running lights. (IMG:style_emoticons/default/smile.gif)
Mar 27 2011, 07:25 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Unhook your 914 battery to prevent the key from ruining your ignition.
RIch |
Mike Bellis |
Mar 27 2011, 09:09 PM
Spend $30 on a drop hitch. 4-6 inches should get the ball down low enough. The angle you have looks scary!
AZ914 |
Mar 27 2011, 09:25 PM
Gint |
Mar 27 2011, 09:29 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
You may want to cover the cars hood somehow so rocks coming off the trucks tires don't chip that pretty black paint. The entire front end will get hammered with whatever debris you kick out from the tow vehicle. Go through some road construction and you're going to be pissed off.(IMG:style_emoticons/default/agree.gif) with everything that's already been said. BTDT |
partwerks |
Mar 27 2011, 09:35 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Beer?
speed metal army |
Mar 27 2011, 09:53 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
U haul car trailer.$49 bux for 24 hours....Way better.
Elliot Cannon |
Mar 27 2011, 10:18 PM
Elliot Cannon |
Mar 27 2011, 10:20 PM
ptravnic |
Mar 27 2011, 10:54 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
I usually put the magnetic lights closer to the rear window on top of the engine lid to avoid air flow moving them/scratching up the paint.
To run the wires, I put the wire from the hitch into the front trunk somewhere near the center and up to L or R side side and out of the front trunk near the cowl area, then through the door just ahead of the small "A" window into the cockpit then under the targa on the rollbar. I think that minimizes any wire to paint slapping. |
Elliot Cannon |
Mar 28 2011, 09:34 AM
I usually put the magnetic lights closer to the rear window on top of the engine lid to avoid air flow moving them/scratching up the paint. To run the wires, I put the wire from the hitch into the front trunk somewhere near the center and up to L or R side side and out of the front trunk near the cowl area, then through the door just ahead of the small "A" window into the cockpit then under the targa on the rollbar. I think that minimizes any wire to paint slapping. Done. Thanks. |
andys |
Mar 28 2011, 11:05 AM
Yes you can back the car. My bud that crewed for a Trans Am team back in the early 70's taught me a trick that works extremely well. Attach two bungee cords at the 6 o'clock position on the steering wheel (assuming a three spoke wheel) through one of the usual holes in the spoke. Anchor one bungee low on the left side and one low on the right; when I did my 914, I had the door panels off, so I anchored to the low parts of the doors. A reasonably stout bungee works best; you may have to mess with the lengths to get approximate equal tension.
I have done this many times, and it does work. Don't expect to make any real sharp reversing turns, but it will allow you to back the car just fine. BTW, the car tracks just fine in the forward direction. When I flat tow for any distance, I remove the bungees and re-connect them when I need to back up; this for safety should one of the bungees de-attach, that would obviously want to turn the car......not good when you're towing forward on the freeway at 60MPH. Andy1 |
Elliot Cannon |
Mar 28 2011, 01:10 PM
Successful tow down to the shop. No problem. I will however buy a new hitch ball that is dropped down about 4-6 inches if I have to tow it over any real distances. Thanks to everyone for the advice.
Cheers, Elliot |
Lo-Fi Version | Time is now: 28th May 2024 - 11:02 PM |
