SDS FI, Need so cal expert to dyno in the FI |
bernbomb914 |
Mar 30 2011, 02:31 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I need someone in So Cal that has a Dyno and knows the SDS FI system to dial in my car so I dont have to guess
Randal |
Mar 30 2011, 03:13 PM
bernbomb914 |
Mar 31 2011, 12:26 PM
yes I need a chassis dyno
Mike D. |
Mar 31 2011, 10:58 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Try Craig at SimTecMotorsports.com. He uses SDS in many custom aplications for all different kinds of cars. He has a DynoPak chassis dyno and is located in Santa Clarita.
Mark Henry |
Apr 1 2011, 07:14 AM
Are you having problems?
I've tuned several SDS systems and as long as I've had a wide band it's never taken me more than a few hours (last one about 20-30 minutes max.) just driving around on back roads. Often the factory mapping from SDS was about 80%+ dead on. I use my modified ashtray mount so that I can program "heads up" on a 914. |
bernbomb914 |
Apr 1 2011, 01:58 PM
It runs under full power but seems a little rich on even throttle. I would like someone to check the installation to make sure it correct as we hand no experience before hand
Mark Henry |
Apr 1 2011, 03:06 PM
What injectors are you running and what is the average duty cycle?
What fuel pressure are you running? Is this a fuel only or a crankfire system. What are the specs on the engine. If you have your map written down post it or send it to me in a PM (or PM me for my email address). |
Lo-Fi Version | Time is now: 14th May 2024 - 10:40 PM |
