bernbomb914
Mar 30 2011, 02:31 PM
I need someone in So Cal that has a Dyno and knows the SDS FI system to dial in my car so I dont have to guess
Randal
Mar 30 2011, 03:13 PM
QUOTE(bernbomb914 @ Mar 30 2011, 01:31 PM)
Neal Harvey of Performance Development is good. He uses Roger Crawford's dyno.
Oh, maybe you are looking for a chassis dyno?
bernbomb914
Mar 31 2011, 12:26 PM
yes I need a chassis dyno
Mike D.
Mar 31 2011, 10:58 PM
Try Craig at SimTecMotorsports.com. He uses SDS in many custom aplications for all different kinds of cars. He has a DynoPak chassis dyno and is located in Santa Clarita.
Mark Henry
Apr 1 2011, 07:14 AM
Are you having problems?
I've tuned several SDS systems and as long as I've had a wide band it's never taken me more than a few hours (last one about 20-30 minutes max.) just driving around on back roads. Often the factory mapping from SDS was about 80%+ dead on.
I use my modified ashtray mount so that I can program "heads up" on a 914.
bernbomb914
Apr 1 2011, 01:58 PM
It runs under full power but seems a little rich on even throttle. I would like someone to check the installation to make sure it correct as we hand no experience before hand
Mark Henry
Apr 1 2011, 03:06 PM
What injectors are you running and what is the average duty cycle?
What fuel pressure are you running?
Is this a fuel only or a crankfire system.
What are the specs on the engine.
If you have your map written down post it or send it to me in a PM (or PM me for my email address).
