Who's got a '75 / '76 rust bucket, i.e. Sawszall candidate... |
jim_hoyland |
Mar 31 2011, 03:23 PM
Get that VIN ? Group: Members Posts: 9,291 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I'm getting closer to doing the bumper backdating on my '75 The bumpers have been straightened and rechromed; the dog bones and hardware are ready; bumper tops done;
My main concern is removing the corner lips that hold the rubber bumpers to the fenders. I'd like to experiment on a discarded piece before starting in on my car and screwing something up. If you know of a possible donor, i'd like to look into feasibility of getting one of two of these sections to practice on. I have a dremel tool as bought a spot-weld drill bit. |
SLITS |
Mar 31 2011, 05:25 PM
One in Riverslime ...............
jim_hoyland |
Mar 31 2011, 05:28 PM
SLITS |
Mar 31 2011, 08:57 PM
One in Riverslime ............... Could it be cut out at G & R ?... Only if you pay me a shit pile of money (IMG:style_emoticons/default/av-943.gif) We started to cut it. I think Glenn cut down the center of the rear trunk, so the edges are still there. Front has them too! Replacement fenders had the lip also. Toast's car ('73) has one replacement front fender, as far as I remember and the bumper fits just fine. Other than that, I have no advice about backdating bumpers. |
ConeDodger |
Mar 31 2011, 09:09 PM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I'm getting closer to doing the bumper backdating on my '75 The bumpers have been straightened and rechromed; the dog bones and hardware are ready; bumper tops done; My main concern is removing the corner lips that hold the rubber bumpers to the fenders. I'd like to experiment on a discarded piece before starting in on my car and screwing something up. If you know of a possible donor, i'd like to look into feasibility of getting one of two of these sections to practice on. I have a dremel tool as bought a spot-weld drill bit. Jim, It isn't that difficult. Use a spot weld bit that you can buy at an autobody supply store. Use a light touch and let the bit do the cutting. That way, all you do is release the spot weld bond and not drill through. Patience is the only tool you need other than that... |
jim_hoyland |
Mar 31 2011, 09:17 PM
I'm getting closer to doing the bumper backdating on my '75 The bumpers have been straightened and rechromed; the dog bones and hardware are ready; bumper tops done; My main concern is removing the corner lips that hold the rubber bumpers to the fenders. I'd like to experiment on a discarded piece before starting in on my car and screwing something up. If you know of a possible donor, i'd like to look into feasibility of getting one of two of these sections to practice on. I have a dremel tool as bought a spot-weld drill bit. Jim, It isn't that difficult. Use a spot weld bit that you can buy at an autobody supply store. Use a light touch and let the bit do the cutting. That way, all you do is release the spot weld bond and not drill through. Patience is the only tool you need other than that... Thanks Rob, I have the spot weld bit now. I want to try it out first before cutting on my car... |
ConeDodger |
Mar 31 2011, 09:19 PM
I'm getting closer to doing the bumper backdating on my '75 The bumpers have been straightened and rechromed; the dog bones and hardware are ready; bumper tops done; My main concern is removing the corner lips that hold the rubber bumpers to the fenders. I'd like to experiment on a discarded piece before starting in on my car and screwing something up. If you know of a possible donor, i'd like to look into feasibility of getting one of two of these sections to practice on. I have a dremel tool as bought a spot-weld drill bit. Jim, It isn't that difficult. Use a spot weld bit that you can buy at an autobody supply store. Use a light touch and let the bit do the cutting. That way, all you do is release the spot weld bond and not drill through. Patience is the only tool you need other than that... Thanks Rob, I have the spot weld bit now. I want to try it out first before cutting on my car... I understand Jim. You'll be fine. Deep breath and go for it... (IMG:style_emoticons/default/biggrin.gif) |
jim_hoyland |
Mar 31 2011, 09:28 PM
[quote name='SLITS' post='1451871' date='Mar 31 2011, 07:57 PM']
[quote name='jim_hoyland' post='1451796' date='Mar 31 2011, 04:28 PM'] [quote name='SLITS' post='1451794' date='Mar 31 2011, 04:25 PM'] One in Riverslime ............... [/quote] Could it be cut out at G & R ?... [/quote] Only if you pay me a shit pile of money (IMG:style_emoticons/default/av-943.gif) We started to cut it. I think Glenn cut down the center of the rear trunk, so the edges are still there. Front has them too! Replacement fenders had the Sounds good, thank you. |
Lo-Fi Version | Time is now: 15th May 2024 - 08:33 AM |
