Removing seam sealer, whats the best/easiest way? |
wrightee |
Mar 31 2011, 06:34 PM
Member Group: Members Posts: 83 Joined: 18-November 09 From: Montclair, VA Member No.: 11,053 Region Association: MidAtlantic Region |
Ok, finally making a little progress on stripping my shell for a couple small rust repairs and repaint. I'm taking it down to uncover any hidden rust, and just took up the floor pan tar with a heat gun. The floors are in real good shape - a tad of surface rust here and there.
Do you all recommend removing the seam sealer, then redoing that after primer? If so, what do you use to get it off? Thanks for any advice. Ed |
Krieger |
Mar 31 2011, 06:44 PM
Advanced Member Group: Members Posts: 4,710 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Your floors look pretty good, but...Start scraping at it with regular old chisel where there is rust next to the seam sealer. Chase the rust until you find none then stop. It comes up nicely where there is rust. IMHO its a lot of work to remove all and may not be worth. Those 3M wheels (drill atatchment) that look like hardened lung tissue work good at removing rust and the seam sealer.
Mar 31 2011, 06:50 PM
needle scaler - cheap at harbor freight
t collins |
Mar 31 2011, 06:54 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
(IMG:style_emoticons/default/welcome.png) fellow VA teener (IMG:style_emoticons/default/beerchug.gif)
Beach914 |
Mar 31 2011, 06:59 PM
Senior Member Group: Members Posts: 964 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
I'm having luck with this on a 4 1/2" angle grinder. Be careful !!! its real wicked to use and you don't want to hit yourself with it.
70_914 |
Mar 31 2011, 11:00 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
Snap On Crud Thug. Just don't get your hand stuck in it...
chrispy |
Mar 31 2011, 11:12 PM
Newbie Group: Members Posts: 48 Joined: 5-May 09 From: modesto, ca Member No.: 10,337 Region Association: None |
I just heated underside with a propane torch (about 10" x 10" area), than scraped with a 3/4 " chisel. Of course I repainted bottom afterwards.
I do enjoy all the ideas that others contribute. there always seems to be a better way. Enjoy |
wallys914 |
Mar 31 2011, 11:55 PM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
Todd Enlund |
Apr 1 2011, 12:04 AM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I'm having luck with this on a 4 1/2" angle grinder. Be careful !!! its real wicked to use and you don't want to hit yourself with it. +1 on the knotted wire wheel. +1 on not hitting yourself with it. It didn't remove as much flesh as I would have expected, but the bruising was impressive. |
jasons |
Apr 1 2011, 07:43 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I'm having luck with this on a 4 1/2" angle grinder. Be careful !!! its real wicked to use and you don't want to hit yourself with it. +1 on the knotted wire wheel. +1 on not hitting yourself with it. It didn't remove as much flesh as I would have expected, but the bruising was impressive. (IMG:style_emoticons/default/agree.gif) On both counts. It will burn through that seam sealer pretty fast. And, wear gloves to protect your digits. |
turnaround89 |
Apr 1 2011, 08:10 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
QUOTE On both counts. It will burn through that seam sealer pretty fast. And, wear gloves to protect your digit (IMG:style_emoticons/default/agree.gif) Wear some goggles as well, the knotted wire wheels will throw the seam sealer all over the place. |
Series9 |
Apr 1 2011, 08:31 AM
Going on right now in my shop.
Like this. Where eye protection. Attached image(s) |
McMark |
Apr 1 2011, 03:43 PM
+1 Torch. Heat it up and it'll separate from the panel, and then a little poke with a chisel will take up large sections. You're not really trying to burn it out. The surface will char and pop and burn, but the point is to heat up the material until it softens.
Wire wheels work, but they're slow, tedious, and messy. Although, for what Joe is doing (floorpan) it'll work better. But for seam sealer in joints and corners, I always grab for the torch & chisel. |
Apr 1 2011, 04:01 PM
+1 Torch. Heat it up and it'll separate from the panel, and then a little poke with a chisel will take up large sections. You're not really trying to burn it out. The surface will char and pop and burn, but the point is to heat up the material until it softens. Wire wheels work, but they're slow, tedious, and messy. Although, for what Joe is doing (floorpan) it'll work better. But for seam sealer in joints and corners, I always grab for the torch & chisel. (IMG:style_emoticons/default/agree.gif) Beware...it is toxic when it burns so wear some protection or expect a headache Rich |
ellisor3 |
Apr 1 2011, 04:09 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I used this 6" wire wheel. It was a little slower than the others but it did not hurt as much either, plus no fear of damaging the metal. Wear leather gloves and eye protection.
http://www.harborfreight.com/6-inch-wire-wheel-46764.html Here is the whole selection: http://www.harborfreight.com/catalogsearch...lt?q=wire+wheel |
Lo-Fi Version | Time is now: 14th May 2024 - 11:42 PM |
