Side marker light assemblies |
abnrdo |
Apr 2 2011, 03:38 AM
Member Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States |
Anyone have a good source for the entire side marker assembly? I specifically need buckets. When the tab broke off on my drivers side assembly the PO just screwed it to the fender. BAH! Now I ahve a hole to fix as well.
-Jim (IMG:style_emoticons/default/headbang.gif) Just getting things lined up so I have plenty of work to do when I get back to the states. |
AndyB |
Apr 2 2011, 04:21 AM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
PM sent (IMG:style_emoticons/default/smile.gif)
type47 |
Apr 2 2011, 05:25 AM
Side marker on the .... well, side, or turn signal? "Bucket" to me sounds like turn signal/
abnrdo |
Apr 2 2011, 09:30 AM
Side marker on the .... well, side, or turn signal? "Bucket" to me sounds like turn signal/ Sorry, its the side marker light. The round one! (IMG:style_emoticons/default/screwy.gif) Brain doesnt work well on the other side of the earth. Plus I am at 6,000 ft! -Jim |
type47 |
Apr 2 2011, 11:18 AM
I have to install side markers too and there are 2 funny little ... "snaps" for lack of better description, that, push in the hole from inside the fender then hold the side marker base (not bucket (IMG:style_emoticons/default/biggrin.gif) ) to the fender by expanding (???) once they are through the base. Hard to describe but I'd bet the holders-on are NLA if you could even find a part number. When I install mine, I'm gonna use some nylon/plastic bolts and nuts I bought at Home Depot that I think will do nicely.
abnrdo |
Apr 2 2011, 12:31 PM
I have to install side markers too and there are 2 funny little ... "snaps" for lack of better description, that, push in the hole from inside the fender then hold the side marker base (not bucket (IMG:style_emoticons/default/biggrin.gif) ) to the fender by expanding (???) once they are through the base. Hard to describe but I'd bet the holders-on are NLA if you could even find a part number. When I install mine, I'm gonna use some nylon/plastic bolts and nuts I bought at Home Depot that I think will do nicely. I believe they are NLA. Anyone completed a 6 conversion and still have the side marker lights? PM me. Both mine are broken. Although, some nylong/plastic bolts and nuts might just work. -Jim (IMG:style_emoticons/default/idea.gif) |
eg914 |
Apr 2 2011, 11:34 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
nylon bolts and nut do work. They have been holding one of my side markers on for several years now.
Mikey914 |
Apr 4 2011, 12:31 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I used plastic pop rivets on mine.
Lo-Fi Version | Time is now: 14th May 2024 - 03:44 AM |
