Just another damned project thread, 914-6 3.2 conversion in GT dress-up |
ConeDodger |
Apr 2 2011, 03:15 PM
Apex killer! Group: Members Posts: 23,569 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
First of all, let me say this: let's not turn this into a 4 vs: 6 thread. I like them both and really don't give a damn about your position on this non-issue.
All the legal stuff out of the way, let's talk engine. First of all, this project is well advanced. The engine is already together and the 20 minute cam run in has been done. But let's talk about how we got to that point first... This motor is a 2432 Raby kit. It uses the LE200 heads and stock 2liter cylinders. The stroked crank is 84mm I believe so think of it as a super-stroker. It will run Jenvey throttle bodies and SDS injection. The EFI sensors I have chosen to use will be TPS, CHT, MAP, IAT, O2 in closed loop, and I think that is everything. Injectors are Ford Red Top. This motor requires quite a bit of engine block clearance so as they say, don't try this at home... It took me about three trips down to Original Customs to put the engine together. I used McMark's shop so I could get his free advice which he of course charges me for, and I don't get distracted by wives wondering how much all of this costs. Plus Mark has an engine break-in stand that allows us to fire it out of the car and correct anything that might be wrong without having to pull an already installed motor. Here is a dyno sheet of one of these motors that Jake actually built. I would expect that my result might be within 10% of his. :Insert fingers crossed smiley here: Attached thumbnail(s) |
Dave_Darling |
Apr 4 2011, 05:42 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
So, any idea why the #1 exhaust pipe got so hot? Was it just for break-in, or was it still doing it the next time you fired it up?
What were you doing with that box and wire near the end? --DD |
ChrisFoley |
Apr 5 2011, 07:29 AM
I am Tangerine Racing Group: Members Posts: 7,911 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
So, any idea why the #1 exhaust pipe got so hot? How could you tell the #1 pipe was hot with the #2 pipe glowing so brightly nearby? (IMG:style_emoticons/default/sunglasses.gif) BTW, running that lean is a quick way to destroy the coating on a header. |
ConeDodger |
Apr 5 2011, 09:24 AM
So, any idea why the #1 exhaust pipe got so hot? How could you tell the #1 pipe was hot with the #2 pipe glowing so brightly nearby? (IMG:style_emoticons/default/sunglasses.gif) BTW, running that lean is a quick way to destroy the coating on a header. Chris, This is not your original coating. They were just re-coated at a Jet Hot facility here before being installed. Once the EFI is on, they will never run that hot again. After the 20 minutes, the header coating looks fine. |
Lo-Fi Version | Time is now: 28th April 2024 - 10:28 PM |
