ConeDodger
Apr 2 2011, 03:15 PM
First of all, let me say this: let's not turn this into a 4 vs: 6 thread. I like them both and really don't give a damn about your position on this non-issue.
All the legal stuff out of the way, let's talk engine.
First of all, this project is well advanced. The engine is already together and the 20 minute cam run in has been done. But let's talk about how we got to that point first...
This motor is a 2432 Raby kit. It uses the LE200 heads and stock 2liter cylinders. The stroked crank is 84mm I believe so think of it as a super-stroker. It will run Jenvey throttle bodies and SDS injection. The EFI sensors I have chosen to use will be TPS, CHT, MAP, IAT, O2 in closed loop, and I think that is everything. Injectors are Ford Red Top. This motor requires quite a bit of engine block clearance so as they say, don't try this at home...
It took me about three trips down to Original Customs to put the engine together. I used McMark's shop so I could get his free advice which he of course charges me for, and I don't get distracted by wives wondering how much all of this costs. Plus Mark has an engine break-in stand that allows us to fire it out of the car and correct anything that might be wrong without having to pull an already installed motor.
Here is a dyno sheet of one of these motors that Jake actually built. I would expect that my result might be within 10% of his. :Insert fingers crossed smiley here:
ConeDodger
Apr 2 2011, 03:16 PM
ConeDodger
Apr 2 2011, 03:17 PM
Custom air cleaners using K&N filters designed by Jake Raby
ConeDodger
Apr 2 2011, 03:20 PM
This engine will be distributorless so this is a couple shots of the Original Customs Hall Sensor mount. Also notice, the crankcase vent that was custom built by Jeff Hines (sixnotfour). This is replacing the distributor and venting the crankcase.
Mike Bellis
Apr 2 2011, 03:22 PM
This is a bad ass build! Rock on!
ConeDodger
Apr 2 2011, 03:24 PM
Here are some random shots of the engine as it goes together...
ConeDodger
Apr 2 2011, 03:25 PM
Here is a close-up of just how much spacer you need to run that much of a stroke. Pretty thick!!!
ConeDodger
Apr 2 2011, 03:27 PM
QUOTE(kg6dxn @ Apr 2 2011, 01:22 PM)
Thanks Mike! I'm just the cook though... Jake was the chef and Mark is supervising the kitchen...
Mark has a video of the cam break in. Maybe he will post that here...
Dr Evil
Apr 2 2011, 03:32 PM
Say what you will, that is beautiful!
I think I'd be a vibrating mess waiting to drive it. Those chart numbers are amazing. And the yellow line for fuel . . . it doesn't use
any Seriously, congratulations on this!!
ConeDodger
Apr 2 2011, 03:38 PM
Some planned locations for SDS components are as follows: The SDS ECU with it's hideous gold anodizing will hide under the passenger seat along with the O2 Sensor control unit. The coil packs will be over on the driver side wall just aft of the relay board. Here is a pic of the vacuum manifold that will collect and smooth the vacuum impulses from the four vacuum vents on the ITB's. This of course will be connected to the MAP. That hideous Eagle will be face down...
The CHT will be in the stock 2liter location and in fact, is the stock Bosch unit. The Intake Air Temperature Sensor will be located between the air cleaners and correct me if I am wrong Mark - on the passenger side? This will use one of McMark's Original Customs designed mounts which he has used on other peoples motors...
ConeDodger
Apr 2 2011, 03:40 PM
QUOTE(MDG @ Apr 2 2011, 01:36 PM)
Mike, I think it is an often overlooked fact that Jake's creations run smoother, use less fuel and run cooler than stock. I'd guess Jake didn't record that parameter 'cause this thing will be thirsty!
I am very excited.
ConeDodger
Apr 2 2011, 03:44 PM
QUOTE(Dr Evil @ Apr 2 2011, 01:32 PM)
Has anyone else noticed that the only people who have responded to this thread are named Mike?
Thanks Evil... As we say in science the rate limiting factor at this point is the custom harness being built by Jeff Bowlsby. The prevalent opinion on the SDS harness was 'cheesy' so Jeff is building a custom one. The plan was to have it done in January but Jeff has some issues personally and professionally right now that are making his life hell and holding the harness up...
76-914
Apr 2 2011, 03:46 PM
Nice job, Sweeeeeeeeeeet. And seeing as how these things usually end up being a 50/50 deal, what did you have to buy her as an offset?
Madswede
Apr 2 2011, 03:51 PM
Very cool!
And even tho I'll have a /6 in my teener, I love big /4's! Look no further than my beloved 968 - 3.0L /4 (inline of course) that I plan eventually to have turbocharged.
Even right now, though, it's around 240 hp naturally aspirated thanks to VarioCam. Once of the reasons I fell in love P-cars in the first place was 'cos they find replacements for cubic displacement ... like good engineering.
I'm now in awe of Jake Raby.
- Nelson
ConeDodger
QUOTE(76-914 @ Apr 2 2011, 01:46 PM)
It's looking like a Cayenne S... Thanks to that provocateur Eric Shea!
rick 918-S
Apr 2 2011, 03:57 PM
Are you planning on attending the WCR with it?
Very nice! You have some of the best of the best working on it too!
VaccaRabite
Apr 2 2011, 04:02 PM
This fills my "coolest thing of the day" slot!
What are you going to do for exhaust? I kinda doubt you are going to be able to use the usual suspects with that much extra space under the cylinders.
Zach
ConeDodger
Apr 2 2011, 04:03 PM
QUOTE(rick 918-S @ Apr 2 2011, 01:57 PM)
I hope so...
QUOTE(ConeDodger @ Apr 2 2011, 05:44 PM)
We move in packs . . .
Krieger
Apr 2 2011, 04:05 PM
Very cool Rob!
ConeDodger
QUOTE(Vacca Rabite @ Apr 2 2011, 02:02 PM)
Zach
I am using Tangerine Racing headers with the O2 sensor bung and heat exchanger option. It has also been drilled for EGT probe. Chris Foley may live on the wrong side of the country from me but his work is well worth the extra shipping. The slip fittings between the sides are plenty long enough so there are no problems...
ConeDodger
Apr 2 2011, 04:08 PM
QUOTE(Krieger @ Apr 2 2011, 02:05 PM)
Very cool Rob!
Andy, It's engine envy. I want to make up for what I lack in talent compared to you with more torque!!!
Krieger
Apr 2 2011, 04:11 PM
Thanks, your gonna have a blast driving that thing!
Andyrew
Apr 2 2011, 04:55 PM
Nice!!! Looking forward to this one!
Some serious $$$$ being put down on this engine.
ConeDodger
Apr 2 2011, 04:59 PM
QUOTE(Andyrew @ Apr 2 2011, 02:55 PM)
Mostly sexual favors but it is nice to know that you think my booty is worth $$$$
Jake Raby
Apr 2 2011, 05:21 PM
The engine that Rob's kit was based from is going into my 356 Outlaw. 220+ HP and an ass load of torque.
Rob, glad you are having fun with this.
ConeDodger
Apr 2 2011, 06:33 PM
QUOTE(Jake Raby @ Apr 2 2011, 03:21 PM)
Thanks Jake! That much HP and torque didn't seem real until we fired it and ran it on the stand. Mark had made braces to keep it from flipping the stand over and it needed it! She ran rough for a minute or two while she warmed up and then became very smooth. This thing is powerful for sure...
patssle
Apr 2 2011, 06:36 PM
So what is the cost, inquiring minds want to know!
ConeDodger
Apr 2 2011, 06:41 PM
QUOTE(patssle @ Apr 2 2011, 04:36 PM)
Oh no you don't... My wife is a member here.
JRust
Excellent Rob! If you bring it to WCR. Just make sure you
the damn thing yourself
. Or tow it yourself
ConeDodger
Apr 2 2011, 06:48 PM
QUOTE(JRust @ Apr 2 2011, 04:41 PM)
I think Jim does plan on coming up with his beer creation... Two Trunk Ale or something like that.
As I said before, if I could change anything other than it not happening, I would just have changed it to me driving. Poor Jim feels pretty badly.
gopack
Apr 2 2011, 06:54 PM
Rob, you make me feel like schmuck for letting my partial car just sit in the garage for the past year. Now that I am moving to a different house, maybe I can get going on it again!
Sounds like my envy will get in the way of our freindship!
Sounds like a great project!!!!!!!!
ConeDodger
Apr 2 2011, 07:08 PM
QUOTE(gopack @ Apr 2 2011, 04:54 PM)
Baloney Mark
Get your tail up to the next reunion and find some motivation there. Leave your cheesehead hat at home though
gopack
Apr 2 2011, 07:24 PM
Next saturday? I'm planning on making it now that the weather is better! Just have to slip out while the wife isnt looking! See Ya next week!
I promise NOT to wear a cheesehead, but I CAN NOT promise not to wear some superbowl XLV gear!
ConeDodger
Apr 2 2011, 07:41 PM
QUOTE(gopack @ Apr 2 2011, 05:24 PM)
Actually a week from Sunday. I am trying to make it possible for Randy to come. He usually can't 'cause he is slinging veggies at work...
Jake Raby
Apr 2 2011, 07:43 PM
It doesn't seem to matter what it costs.. Our kit program is slammed until November and we only have one slot left open then for a February 2012 delivery.
To build an engine from scratch like this is a 10K+ expenditure to incklude the kit, induction, exhaust and ancillaries. In turn key form its around 13K hot off my dyno in a crate like this one, ready to run.
ConeDodger
Apr 2 2011, 07:51 PM
QUOTE(Jake Raby @ Apr 2 2011, 05:43 PM)
Click to view attachmentActually, someone asked how much at Original Customs last weekend while I was working on my car. A 912 guy. That was exactly the answer I gave him and Mark agreed. I have no idea really.
All I can say is work hard so you can write checks that don't bounce...
raw1298
Apr 2 2011, 11:29 PM
I cant wait to see this in person. Looks like fun!!!
AndyB
Apr 3 2011, 04:47 AM
QUOTE(Jake Raby @ Apr 2 2011, 09:43 PM)
In turn key form its around 13K hot off my dyno in a crate like this one, ready to run.Click to view attachmentSo you are saying that a turn key engine just like this is 13K? Thats what I am reading here. Must have missed that one on the website
ConeDodger
Apr 3 2011, 11:54 AM
QUOTE(Scarlet75 @ Apr 3 2011, 02:47 AM)
There is a good deal of stuff you must supply. That can add thousands depending on what you have and what you need to source. The nice thing about Jake's turnkey program is that it comes out of that box, broken in, tuned and ready to go...
JRust
Apr 3 2011, 12:06 PM
QUOTE(ConeDodger @ Apr 2 2011, 05:48 PM)
We definately want Jim there
. I know there are a few of the home brewing guys looking forward to what is coming
. I sure feel for Jim. I have driven friends 914's before & had mine driven by others. That kind of scenarion is everyone's nightmare.
happens though & is past. It will be great to see your 914 in all it's new glory
0396
Apr 3 2011, 01:58 PM
Congrats!!.. When you start walking away from some of the cars out there, they will be scratching their heads
Cost wise ya.. bring lots and lots of it. Then an old Porsche tech mentioned way way back- if you want to play – bring $.
PeeGreen 914
Apr 3 2011, 02:00 PM
I'd just like to say I hate you and never want to talk to you again
Okay, in all honesty, this is one of the coolest things I've seen in a while
Now, I will be sure to take a few great shots of your car near some classy garbage cans at the WCR.
Rob, you sure do have some cool toys
patssle
Apr 3 2011, 03:20 PM
Oh I wasn't interested in buying, just curious to compare it to my /6 conversion which seems to be around the same HP.
ConeDodger
Apr 3 2011, 03:37 PM
QUOTE(patssle @ Apr 3 2011, 01:20 PM)
But 150# heavier. But as I said, this thread isn't about that so don't go there...
ottox914
Apr 3 2011, 04:26 PM
I had a little preview of this when I was in CA a month ago or so. Nice motor. If those dyno charts on page 1 are even close to what you'll be making, HOLD ON!!!!
I can only hope once I get the turbo motor perfected I'll be in that ballpark.
Congrats on a great project! Now bolt that thing in and go zombie hunting!!!
Jake Raby
Apr 3 2011, 04:34 PM
QUOTE(Scarlet75 @ Apr 3 2011, 03:47 AM)
This combo isn't on the site as an advertised offering. This is a full custom build that I choose to offer to some purchasers that have cars that are properly set up for this type of power.
Yes it is expensive and it always will be.
914Mike
Apr 3 2011, 08:45 PM
QUOTE(ConeDodger @ Apr 2 2011, 02:44 PM)
Yup!
Looks good! I see you're full-flowing it.
ConeDodger
Apr 3 2011, 10:19 PM
Yes, we have most definitely left this in the past...
