This is an idea I had which I ran by McMark. He didn't shake his head and say something demeaning so I contacted Jeff Hines (sixnotfour) who quite quickly ran me up two of them with different sizes on the hose bib... This of course, takes the place of the distributor since this engine will be crank fired. Both the head vents have been plugged and we will be venting the case through here and returning any oil through the the old PCV hole in the oil console...
I cannot caution enough, do not build an engine without properly venting the case. You could blow out seals and have leaks that will be legendary!
