ConeDodger
Jan 17 2017, 01:47 PM
Here's another. Same housing, different lighting. LED wins!
ConeDodger
Jan 17 2017, 03:30 PM
These are beautiful. Here you see the originals followed by 914Rubber's reproduction. They really pop!
jim_hoyland
Jan 18 2017, 07:29 AM
Headlight mod looks great Rob; what is the wattage of the bulbs and how much voltage do they consume
ConeDodger
Jan 18 2017, 08:41 AM
QUOTE(jim_hoyland @ Jan 18 2017, 10:29 AM)
I'll refer you to Mark Whitesell on that. I'm back to work in California. Day two of my 7 day sentence...
ConeDodger
Feb 1 2017, 05:30 PM
I suspect this is mine. McMark posted it on Facebook on the Original Customs page. If it is, and I'd say that's likely from his description, we are getting closer to the Original Customs Cable Shifter!
Sorry, what is it? It's the 915 out of my 84 911. It ate a few gears one night on my way home from work. Mark is replacing the gears and synchro and putting a Quaffe TB diff in it.
Feb 1 2017, 08:44 PM
QUOTE(ConeDodger @ Feb 1 2017, 06:30 PM)
That's good news. I'll be in the market for a 915 cable shifter.
ConeDodger
Feb 2 2017, 02:03 PM
I spoke too soon. A check of the main case reveals that I have loose bearing races. The main case has to go to WEVO for repair. So, the development of the cable shifter will have to wait a little longer...
ConeDodger
Feb 21 2017, 08:39 PM
On a side note, I picked up this today and hauled it home. It's a Rebello 3.0 L Series Datsun motor for my 240Z. 300HP, 290lbs/ft of torque. This will be Megasquirt and crank fired.
Sitting in the back of my truck still. I'll get it out and on the stand in the morning.
ConeDodger
Apr 17 2017, 11:16 AM
I got a telegraph from Grand Rapids Michigan today. That McMark guy has been at it again. The plan originally was to go with a 915 transmission in my car. Then, we discovered that my 3.2 needs a top end rebuild due to valve guide issues. So the car will be going to Original Customs this fall to do the top end and install this thing of beauty. '84 911 915 transmission, flipped and Quaiffed. Those Original Customs boys are really artists!
Dave_Darling
Apr 17 2017, 11:21 AM
Did you get the Wevo bearing retainer bits as well? I hear that the 915 bearings can walk without it. Though that shiny intermediate plate might also prevent that...
--DD
McMark
Apr 17 2017, 11:25 AM
Looked into it. Decided that it was beyond the scope/necessity of this transmission's life style.
ConeDodger
Apr 17 2017, 11:28 AM
QUOTE(Dave_Darling @ Apr 17 2017, 02:21 PM)
--DD
I had to Dave. A month or so back, I got a text from Mark saying my bearing retainer had already gone to lunch.
all together, the Quaiffe and gears and synchro, along with the bearing retainer and intermediate plate, cost more than my 914 did when I bought it!
But I bet it will shift like a dream and that has been my one persistent complaint about these cars...
Oh, I guess we were talking about two different things. *Edit*
McMark
Apr 17 2017, 11:36 AM
Apparently we might not all be talking about the same thing. There are three upgrade/repairs offered by Wevo:
1: Main Case Repair - This is the case section pictured above, and encases the gear stack. This piece mostly resembles the intermediate plate on a 914/901. There are two roller bearing races pressed into this housing, and they can become loose over time. Wevo machines out the old bearing bore section and installs a brand new aluminum section to revitalize.
2: Differential Housing Repair - This is the section of a 915 where the differential lives. This section also has two roller bearings that oval out. Wevo also repairs this section by machining out a the bad section and installing a steel insert. This case section gets steel because the side load forces are greater.
3: Bearing Retainer - The stock 915 has two individual bearing retainers capturing the bearings in 2: Differential Housing. Wevo designed a single piece to replace both stock parts. The idea is that by tying the two together they will support each other and help guard agains future bearing slippage.
For Rob's transmission, we just did #1. The rest of it was fine. And then for the differential flip we bought the Wevo side cover which is machined to accept the stock speedo sensor. Buying their part was cheaper and better than machining the stock side cover for the speedo sensor.
ConeDodger
Apr 17 2017, 04:48 PM
Lately, we've had a bit of vendor bashing what with PMB having one of their vendors drop ship the wrong part. It's good to remember that most of our suppliers are small. Mark sent my 915 case to WEVO for the repair and said I could just call and pay them directly. I probably called 8 times over a couple weeks and ultimately, just stopped and knocked on the door. Nothing... I called Mark after the stop and knock and he gave me some perspective. They're very small. Maybe even husband and wife small.
Have some patience people..
Dave_Darling
Apr 17 2017, 05:21 PM
I believe I've stopped over at their shop before. Yeah, not exactly an international super-conglomerate.... But dang, if they don't make neat parts!
--DD
ConeDodger
Apr 17 2017, 05:33 PM
QUOTE(Dave_Darling @ Apr 17 2017, 08:21 PM)
--DD
Yup...
ConeDodger
Apr 18 2017, 12:05 AM
And as if Mark finishing up the 915 conversion wasn't enough, I just got home from my week of work in California and I found a box from PMB!
This is the promo pic from Eric's website. I'm too lazy to open the box right now. Ok, I opened one of the boxes! Oh fuch! They are so damned light! He loaded them with Porterfield R4S pads too! I know what I'm doing tomorrow!
Oh, and forget it. This was the last set.
raynekat
Apr 18 2017, 01:46 AM
QUOTE(ConeDodger @ Oct 8 2016, 08:00 PM)
Guys, I am not starting a list. Once I get these done, I'm sending them to PMB and you will be able to get them from Eric...
Did the rear fog light brackets ever get any traction?
Did any get made up and make their way to PMB?
Curious as I'd like to buy some soon.
Need to get the holes drilled before my car goes into paint.
ps if those are the alloy rear brakes, I'm sick....with envy. Wanted some, but was too late as they were all gone.
McMark
Apr 18 2017, 05:34 AM
The foglight brackets need me to media blast all of them and get them zinc plated. In fact, I'll head over to the blast cabinet and see how many I can get done right now...
ConeDodger
Apr 18 2017, 08:19 AM
QUOTE(raynekat @ Apr 18 2017, 04:46 AM)
They are the alloy rear brakes...
Once McMark blasts the mounts, they will be plated and the group buy will begin. Oh, and Mark, not Eric will handle the group buy.
ConeDodger
Apr 22 2017, 02:40 PM
Apparently, using the 4 cylinder tach in in your DME 3.2 conversion is death to the ECU eventually. Thanks to, I believe Mepstein for researching this and reporting on his chat with Steve Wong on the subject. After reading that a month or so back, I've been afraid to drive the car for fear of taking out the ECU! Who would of thought it wasn't as simple as dividing by 3 and multiplying times 2?
I've had the Carrera tach in a box having had it refurbished by North Hollywood Speedometer. I did a search and found the proper PIN numbers posted by Joe O'Brien a few years back. I confirmed the info was correct with McMark and Mark added the wire colors to the PIN number connections.
So now, I have a properly functioning 6 cylinder tach!
Tach signal / black/purple / pin 2
12 volt power / red/white / pin 5
Ground / brown / pin 6
Here she is!
Yes, I know. No silver button on the speedometer. The Carrera speedometer is also in a box. It needs that shiny 915 transmission to work so, it's coming soon!
ConeDodger
May 21 2017, 06:48 PM
Now if I could just get Whitesell to make those targa bar pads. Maybe I should start a thread and have everyone bomb his email inbox...
Rand
May 21 2017, 06:57 PM
QUOTE(ConeDodger @ May 21 2017, 04:48 PM)
LOL, Rob. I think Mark has heard the message. Step away from the pom poms.
Of course I haven't heard a timeline? ;p Ok, pick 'em back up.
ConeDodger
May 21 2017, 07:02 PM
ConeDodger
Jun 7 2017, 10:58 PM
Since this is 'the story of my 914' I thought I'd put some of the really great pictures taken by a few of my fellow WCR 2017 pals...
tygaboy
Jun 7 2017, 11:22 PM
And another!
Harvey Weidman
Jun 8 2017, 09:42 AM
Those are actually some of the coolest photos of your car that I have seen.
H
Those are some nice pix Rob!
Steve
Jun 8 2017, 11:02 AM
Beautiful car and pictures. Can't wait to get my car painted.
ConeDodger
Jun 8 2017, 11:09 AM
QUOTE(Harvey Weidman @ Jun 8 2017, 12:42 PM)
H
Thanks Harvey. Everyone who sees it loves the wheels so you're a big part of that!
ConeDodger
Jun 8 2017, 02:38 PM
I got an offer I couldn't refuse as they say. 914Rubber is running an excellent group buy on the reproduction dashboard they developed. I've seen one. They're excellent!
My dashboard is a leather covered "916" dash. I've decided I want to go more original.
Can't wait!
arne
Jun 8 2017, 03:08 PM
Wait... GB on a dash pad? How'd I miss that? Where's the thread? I'm going to need one before long.
ConeDodger
Jun 8 2017, 05:47 PM
More...
bigkensteele
Jun 8 2017, 07:19 PM
QUOTE(arne @ Jun 8 2017, 01:08 PM)
It was before you joined. I had an NOS pad still in the box. I shipped it out to Mark, and he cut a mold. The original dash was destroyed in the process, but when I got the new one, I literally can't tell the difference. It is that good. Actually, I think that it might be better as the construction technique will lend itself to less cracking than the original.
infraredcalvin
Jun 8 2017, 07:53 PM
Beautiful Car and great pics, your car has been inspiration since I first saw it completed on the board. Makes he want to paiint mine the original diamond silver metallic....
ConeDodger
Jun 8 2017, 08:16 PM
QUOTE(infraredcalvin @ Jun 8 2017, 10:53 PM)
Well thank you. You're very kind. If I were where you are in your project, I'd go Conda Green and do a Moritz replica!
JmuRiz
Jun 9 2017, 10:49 AM
QUOTE(ConeDodger @ Jun 8 2017, 12:38 PM)
Can't wait!
Vulture circling....how much for the leather dash
I want to replace my dash-cap covered part...even though it looks great.
ConeDodger
Jun 9 2017, 11:31 AM
QUOTE(JmuRiz @ Jun 9 2017, 01:49 PM)
Can't wait!
Hahaha! Nathan, you got me! I went back and looked at all the pics I just posted for the vulture and then realized you're the vulture!
If you're serious, PM me. I'll get you some pictures and figure out a price. It's kind of inappropriate to be selling it here in this forum and that wasn't my intention.
Jun 9 2017, 11:34 AM
QUOTE(ConeDodger @ Jun 7 2017, 09:58 PM)
Nice pictures but i think you need a bigger motor ...
ConeDodger
Jun 9 2017, 12:27 PM
QUOTE(SirAndy @ Jun 9 2017, 02:34 PM)
You know, when you would go by me last weekend and I heard the music coming out of your exhaust, even I thought I needed a bigger motor!
McMark
Jun 9 2017, 02:31 PM
Turbo > Displacement
ConeDodger
Jun 9 2017, 02:45 PM
QUOTE(McMark @ Jun 9 2017, 05:31 PM)
Just one?
ConeDodger
Jun 9 2017, 03:11 PM
Ahh damn it Mark! Now you've got me thinking...
3.5 liter turbo nickies and pistons
Headwork and cams
Fancy exhaust and turbos. BOV, some kind of EMS and sensors.
Huh, we're over $10K before we get to bending up a turbo exhaust system or your labor!
Harvey Weidman
Jun 9 2017, 04:21 PM
Hand grenade > Turbo....
Jun 9 2017, 04:24 PM
QUOTE(Harvey Weidman @ Jun 9 2017, 03:21 PM)
Harvey Weidman
Jun 9 2017, 05:21 PM
QUOTE(SirAndy @ Jun 9 2017, 03:24 PM)
Sorry, It wasn't personal....
Just when a Turbo passes me there usually is some parts of melted piston coming from the exhaust....Not yours of course..
ConeDodger
Jun 9 2017, 05:41 PM
QUOTE(Harvey Weidman @ Jun 9 2017, 08:21 PM)
Sir Andy is turboless...
Harvey Weidman
Jun 9 2017, 07:40 PM
QUOTE(ConeDodger @ Jun 9 2017, 04:41 PM)
Then I really am sorry....
burton73
Jun 9 2017, 08:35 PM
Rob,
Are the wheels called a RSR finish? Your car is stunning.
Thanks,
Bob B
ConeDodger
Jun 9 2017, 10:23 PM
QUOTE(burton73 @ Jun 9 2017, 11:35 PM)
Rob,
Thanks,
Bob B
Thank you Bob, but the wheels were the product of Harvey Weidman, the guy who posted just above. They are indeed RSR finish. Harvey took 2 16X6 Fuchs to make each of the 16X8.5 rears. The fronts are 16X7. I'm amazed actually at how durable the finish is. They just stay looking great.
Another testament to Harvey's knowledge of these cars, look how these rears fit. With the original factory flares they would have been like gloves, with the reproduction flares, a little trim on the flange was necessary. They are so well fit and I didn't realize just how well until after. Harvey's working on a second set of polished wheels for the car too. Just for fancy occasions!
